After I jaik broke the iPad the wallpaper changed and it shuted off, then startet to only show the loading signal. It been too long showning the loading mark IT TOOK MORE THAN FOUR HOURS AND THE IPAD DIDN'T STARTED YET, HELP!
This is a discussion on After JailBreaking, iPad take forever to load!!/HELP ASAP. within the iPad Hacking forums, part of the Apple iPad Discussions category; After I jaik broke the iPad the wallpaper changed and it shuted off, then startet to only show the loading signal. It been too long ...
''Once you taste Apple, nothing else taste like Apple''.
Now fixed it, but now there is a new problem some thing about springboard crashing and they ask me to restart the wallpaper change but it no use. Experts help please?
Maybe you should not panic I suggest you read our threads in the forum ok
You are in control of your own world if you choose to break the iPad. From what I have read many have done successfully so relax think make a list of your problems and ask how we may be able to help with out spitting the dummy ( going into a panic)
Cheers col
restore and jailbreak again. it should work.
What jailbreak apps did you install?
I restored and installed jailbreak all over again. Hopefully I won't run into this problem again.
