Results 1 to 10 of 17
    118968
    Oct 2011
    Spain
    8
    Volume button mutes the sound completely with one push only! Please Help
    Hi everyone!
    I have a Jailbroken iPad1 with all the latest updates from Cydia for Springboard, SBSettings, etc.
    Suddenly the volume rocker down button goes completely down when pushing it down, like the default behaviour when you
    keep pushing the button down for muting, but with just one quick push on the button, the weird thing is that
    if i restart the device, the first two pushes down work perfect and are shown on the screen overlay, but at the third
    push down it goes all the way down and mutes the device. The up volume button works perfect everytime but from then on,
    the down button only mutes the device. This is driving me crazy to fix, I know it's jailbreak related or with a problematic update
    for a Cydia App because if i enter Safe Mode the volume button behaviour is normal (the down volume button works as expected every time).
    Also I disabled every mobilesubstrate tweak and it keeps happening... I will appreciate any help on this.
    Thanks in advance,
    Carlos.
    13576
    801 times
    Aug 2010
    Western NY state (USA)
    9,441
    Unfortunately, I tried what you described. And, I find I am able to exactly replicate your problem - with no fix that I know of either! So now, my iPad is acting weird, also! Well, it's probably been acting weird for a while - now I just know about it. Thanks for that ... I think.
    All I've done is like you ... I've installed the updates that are mainly being updated for compatibility with iOS5. So, what I'm thinking is that whatever "they" have done to the various tweaks you and I have on our iPads to make them compatible with iOS5 makes it act a bit strange on iOS 4.3.3. Well, on my 4.3.3-running iPad (you didn't say what version you are running).
    With all that said, all we can do is either (1) ignore the problem and hope another one - even worse - doesn't manifest while we're waiting to move up to iOS5 or (2) move on up to iOS 5 and do a tethered jailbreak.
    Not so good choices, yeah? But, that's all I've got ... and what I'm now faced with. Sorry.
    P.S. I also have a weird reset problem - in that it takes a couple of resets plus a respring (sometimes) to get my iPad1 to look/behave properly. Again, I've been putting that down to the iOS5 upgrade tweaks, as I've not added a new tweak in ages...
    P.P.S. Oh, this is just great! Now that you've mentioned it, and I've discovered it, it's going to bother the heck out of me. So, now to make my decision - go up to iOS5 with a tethered jailbreak or not... Sigh. Again, thanks!
    P.P.S. So, anyone who's gotten this far and are running an iOS5 tethered jail break on the iPad1 ... how is it? Pretty stable? Cause 4.3.3 is (well, was) and I'd like the same on iOS5...
    118968
    Oct 2011
    Spain
    8
    Thanks Marilyn, your post is informative and it indicates that our problem is a result of a recent update for iOS5 compatibility. Personally, I'm satisfied with iOS4.3 and will not upgrade. But this bug is quite a pain in the *ss...
    If you or anyone reading this knows where we can notify the jailbreak community developers about this so they can fix it, it should be great.
    I searched for a forum where we can post bugs regarding cydia apps but found none.
    118968
    Oct 2011
    Spain
    8
    Also It could help to be able in Cydia to install a previous version of a cydia tweak, anyone knows if its possible?
    Thanks, in advance,
    Carlos.
    118968
    Oct 2011
    Spain
    8
    Sorry, I'm running iOS 4.3.1, forgot to mention.
    13576
    801 times
    Aug 2010
    9,441
    Just adding a line to say that I've moved this post over to the Hacking Section ... which is what I should have done when I first posted.
    We now return you to your regular programming...
    86390
    Aug 2011
    Essex, UK
    30
    I've just noticed this problem last night too - for the life of me I can't remember what I've updated recently but I'm running jailbroken 4.3.3 iPad 2 .
    14571
    603 times
    Sep 2010
    Troon, Scotland
    7,059
    Try resetting all the Activator actions to default in the activator settings. I had a few problems with gestures not working as expected after the upgrade, and this fixed it, and I can confirm that my iPad1 on 5.0 is not displaying this behaviour...
    Good luck.
    PS - Nor is my iPad2 on 4.3.3
    iPhone5 32GB 6.1.2 (evasi0n) | iPhone4S 64GB 5.1.1 (absinthe) | iPhone4 32GB 7.0b (stock) | iPhone3G 16GB 3.1.3 (jbme) | iPod Classic 6G 160GB (stock) | AppleTV 2G 5.0.2 (seas0npass)
    16187
    Sep 2010
    USA
    10
    I had this problem and can confirm that resetting the Activator settings to the default settings fixed it.
    *edit* Well I spoke too soon. The problem is back. The solution lasted until I turned the volume down a couple of times then came back. I think and app or Cydia app may be the problem. Perhaps it's an app that was updated to be iOS 5 compatible but messed up 4.3.1.
    116609
    5 times
    Oct 2011
    168
    it happened to my vol. control as well ... ipad2 3G-wifi jailbreak at 4.3.3 .. i just ignored it .. cydia has a bunch of updates recently which made the previous vers acting "differently"' .. most noteable in the winterboards .. some i wished i did not upgrade
  1. Volume button
    By RudyL90 in forum iPad Hacking
    Last Post: 08-19-2011, 01:31 PM
  2. Problem with volume button anyone?
    By lmdarkins in forum iPad 2 Forum
    Last Post: 05-20-2011, 08:25 AM
  3. Volume button doesn't mute
    By BC1973 in forum iPad Help
    Last Post: 05-16-2011, 08:19 AM
  4. Disable volume button?
    By Mattmilw in forum iPad Help
    Last Post: 04-16-2011, 10:25 PM
  5. Looking for app to import small wav files and play at push of a button
    By Jcpzero in forum iPad General Discussions
    Last Post: 07-03-2010, 02:59 AM
activator volume down mute
ipad volume button mutes
ipad volume button muting
ipad volume button muting one click
ipad volume down acting as mute
ipad volume down goes mute
ipad volume down mute
ipad volume down mutes
ipad why i press volume down it goes all the way
jailbroken ipad volume down mutes
volume down ipad mutes
volume key mutes sound ipad jailbroken
