1TB HDD on iPad2 - step by step guide - Camera Connection Kit
This is a discussion on 1TB HDD on iPad2 - step by step guide - Camera Connection Kit within the iPad Hacking forums, part of the Apple iPad Discussions category; Thank you very much, Dan! I have got it by using Acronis Disc Director. I wish I could find a decent external battery pack to ...
Page 4 of 4 FirstFirst ... 2 3 4
Results 31 to 37 of 37
Like Tree4Likes
Thread: 1TB HDD on iPad2 - step by step guide - Camera Connection Kit
  1. #31
    229274
    Jul 2012
    7
    Thumbs up
    I wish I could find a decent external battery pack to power the External HD for 12/24 h, instead of using the USB port of my laptop. Which minimum power and charging requirements would be needed?
    IMP battery packs are no more sold to Brazil.
    Quote Originally Posted by Danfozzy View Post
    Aye, it's just the original poster saying something about lba, not sure how to go about that and can't seem to find an answer on it
    Scratch that, acronis disc director can format it to fat32 lba
  3. #32
    244923
    Sep 2012
    HAWAII
    I have tried to follow these direction with no success, ifile never reads the portable drive. Im not sure if i'm formatting the drive correctly. When I toggle Usb via sbsettings a error message stating that the hd...... device is not ready/not present. The drive is FAT32 format but not sure if I got the bootable (LBA) part correct. I also get the error message device requires too much power when I plug the drive in. I have bought two extra Y cables thinking that may have been the problem to no success. Do you have any ideas??
  4. #33
    155195
    3 times
    Jan 2012
    90
    What are you using to power the drive? If you are getting the "too much power" message you are not supplying adequate power to the external drive.
  5. #34
    190692
    Apr 2012
    memphis
    38
    I use an AirStash+ with 64 GB SDXC cards to read and write to from my iPad3. Greatest thing since sliced bread
  6. #35
    244923
    Sep 2012
    HAWAII
    Quote Originally Posted by dreyoung View Post
    Im using a "y" cable plugged into my standard mac wall power adapter with a toshiba 1tb. Im still getting the power error.
  7. #36
    155195
    3 times
    Jan 2012
    90
    Is the toshiba drive designed to be powered from the USB port? Some require their own separate power in addition to the USB connection.
  8. #37
    yof
    yof is offline
    180717
    15 times
    Mar 2012
    EST
    162
    Try a different wall power adapter not for mac. It might have restrictions on how much the hard drive needs. Also try switching the cables around. Few cables have been marked that some are designated to be power and one for data. Some don't. Also try with another portable hard drive if you can with those y cables. The USB toggle tweak might be friendly but not as reliable as the manual way. You can find more information in the stickied posted above in the Hacking section called "Using External Storage Devices with the iPad "
  1. Step By Step Airplay Mirroring on iPad2 + AppleTV 2G
    By soccerking888 in forum Apple TV
    Last Post: 01-05-2012, 10:58 AM
  2. Pls help...confuse about process/step
    By SueInBoston in forum iPad General Discussions
    Last Post: 04-24-2011, 06:11 PM
  3. Step by step help with jailbreak?
    By Dolfanpete in forum iPad Hacking
    Last Post: 04-07-2011, 09:26 AM
  4. Replies: 3
    Last Post: 03-15-2011, 08:38 AM
  5. Step-by-Step Guide to Playing SNES Games on Your iPad
    By Maura in forum Apple iPad News
    Last Post: 07-17-2010, 08:25 PM
camera connection kit ifile
camera connector ifile folder
harddisk ipad2
how to add a external hard drive to jailbroken ipad 2
how to mount an harddrive to ipad 3
ifile camera connection kit
ifile usb hdd
ipad 1 camera connection kit hack
ipad camera connection kit hack
ipad hdd
usb hdd to ipad 2
usb toggle with camera connection kit
