Need help
This is a discussion on Need help within the iPad Hacking forums, part of the Apple iPad Discussions category; Hi all, I need some help. I have the original iPad and jail broke it a while back with jailbreak.com. Later I removed the jailbreak ...
Results 1 to 3 of 3
Thread: Need help
    110317
    Oct 2011
    Need help
    Hi all,
    I need some help. I have the original iPad and jail broke it a while back with jailbreak.com. Later I removed the jailbreak thinking all was ok. I was able to update the software later to 4.3.2 and thought all was ok. However I have come to update to ios5 and I get a error about the update being not eligible for my iPad. This can only be due to the original jail break.
    Is there a way I can restore my iPad back to the way it was before I jail broke it. I have seen about blobs and the like and don't have any as far as I can see because it was done through jailbreak me. I don't know what to do. I have connected it to tiny umbrella in the hope that would fix it but nothing.
    Any ideas?
    Many thanks for all your help in advance
    14571
    596 times
    Sep 2010
    Troon, Scotland
    7,049
    Sounds like you redirected your hosts file to point at Cydia. You need to point back at Apple. Follow the "solution" part of this guide and you will be good to go - HOW TO - Resolve iTunes Unknown Error 3194
    110317
    Oct 2011
    Hi,
    Thanks for the reply. I though it could be that as I had the same issue with the iphone 4. Unchecked the box and my iphone was workig again. Thinking the same i thought i would do it for the ipad. However the box is already unchecked! I am at a real loss!
