Closed Thread
Results 1 to 10 of 18
Thread: Cydia problem
    83018
    Jul 2011
    18
    Cydia problem
    Can anyone help me or point me to a forum that can? I downloaded dreamboard from cydia and 2 Dreamboard
    Themes last night. But I don't like it and want to remove them. When I go into cydia and hit uninstall and can't
    uninstall it. I get a message for dreamboard and each of the themes as it starts the uninstall process. I get two messages in red. The first says,"trying to overwrite/Applications/Dreamboard app/icon.png which is also in package.com.wynd.dreamboard. Then right below this message in red I get the message "subprocess/usr/binldpkg returned an error". Now I can't remove dream board and the two themes. Can anybody help me erase Dreamboard and these two themes? Thank you
    14571
    603 times
    Sep 2010
    Troon, Scotland
    7,059
    You aren't actually running Dreamboard before you go into Cydia are you? Best to make sure you fully exit Dreamboard, reboot the iPad, and then remove them. Start by removing both themes first, then the actual Dreamboard app.
    Let us know how you get on.
    iPhone5 32GB 6.1.2 (evasi0n) | iPhone4S 64GB 5.1.1 (absinthe) | iPhone4 32GB 7.0b (stock) | iPhone3G 16GB 3.1.3 (jbme) | iPod Classic 6G 160GB (stock) | AppleTV 2G 5.0.2 (seas0npass)
    Banned
    12904
    34 times
    Aug 2010
    Raleigh, NC USA
    3,655
    Go back to the stock theme, (aka in dreamboard, don't have any themes running. Then go to Cydia and uninstall.
    83018
    Jul 2011
    18
    Closing dreamboard
    Dumb question but how do I close dreamboard or the theme? When I got into dreamboard, there is just the honeycomb theme. When I hold down the honeycomb theme I only have 3 choices, edit, reset and cancel. So I don't know how to close the theme and I don't see any options to close dreamboard. How do I do this? Thanks
    14571
    603 times
    Sep 2010
    Troon, Scotland
    7,059
    Just turn your iPad off and back on again for ease...
    83018
    Jul 2011
    18
    I do that and the dreamboard and honeycomb theme are still active and on
    Banned
    12904
    34 times
    Aug 2010
    Raleigh, NC USA
    3,655
    Go to your apps and tap on dreamboard. Then tap on the stock theme.
    Uninstall your theme.
    14571
    603 times
    Sep 2010
    Troon, Scotland
    7,059
    Quote Originally Posted by ccohen6410
    Are you sure you are rebooting? AFAIK Dreamboard cant auto-start. It certainly does not on my iPad.
    83018
    Jul 2011
    18
    I assume I am rebooting by turning the ipad off. So yes, I assume i am rebooting. If this is wrong please let me know the right way to do it. Thanks.
    14571
    603 times
    Sep 2010
    Troon, Scotland
    7,059
    You turn the iPad off fully by holding the power button for several seconds until the slider pops up. Then you turn it off. Once that is complete you can turn it back on again by pressing the power button. You will see the Apple logo for about 30 seconds. Dreamboard should not be running if you do this.
Closed Thread
  1. Help! Problem installing sources in cydia!
    By Serianni in forum iPad Hacking
    Last Post: 08-17-2011, 06:47 PM
  2. Cydia Refresh Problem
    By Munky in forum iPad Hacking
    Last Post: 02-07-2011, 11:38 PM
  3. Cydia problem
    By lrg32 in forum iPad Hacking
    Last Post: 02-01-2011, 04:30 PM
  4. Problem with downloads of files from Cydia page
    By rafael73 in forum iPad Help
    Last Post: 10-12-2010, 11:02 AM
  5. Cydia update problem
    By Luketaytay in forum iPad Hacking
    Last Post: 08-17-2010, 06:35 PM
can't remove dreamboard
can't uninstall dreamboard
close dreamboard
com wynd dreamboard error
com.wynd.dreamboard
com.wynd.dreamboard error
how to exit a dream board theme
how to exit dreamboard on ipad
how to uninstall dreamboard ipad
remove dreamboard
trying to overwrite which is also in package ipad
wynd dreamboard problem
