Results 1 to 7 of 7
    38551
    Chicago
    12
    i've tried un-jailbreakbreak/restoring my ipad it will not work HELP
    I've tried restoring my iPad back to factory settings. I've tried on 2 different computers and it still will not work, when it gets to a certain percentage it gives a error message and say file corrupt.. I've gotten two error messages from two different computers.. the iPad have not been connected to iTunes in about 2 months while jail-broken.. now that i am trying to restore it i cant .. already updated iTunes to the latest version still not working on either computer... is there another way to hard reset it without iTunes cause those files will not download for me and i hit restore and update in the summary portion of iTunes ... Please help
    13576
    803 times
    Aug 2010
    Western NY state (USA)
    9,454
    Try this:
    Download the latest version of iOS 4.3.5 from here: Official Apple IOS Firmware Download Links for iPad
    NOTE: If you are using Internet Explorer to do the download, it will probably try to make the file a .zip file, when it should end in IPSW. If that happens, just change the .zip to .IPSW (do NOT unzip it!). Oh, and remember where you put it ... !
    Connect your iPad to the computer (with iTunes NOT running) and then put it into DFU mode (if you need 'em, the instructions are here: DFU Mode for Dummies). Once the iPad goes into DFU mode, iTunes should open and say that it detected an iPad in restore mode. Accept that pop-up...
    Then, press shift and hold it while you click on the restore button in iTunes.
    A pop-up window should appear for you to browse and locate that iOS 4.3.5 IPSW file you just downloaded.
    Then, iTunes should take over and do a bunch of stuff - the end of which should be an iPad restored to iOS 4.3.5. You can then either elect to restore from backup or to create a new iPad (<--- that will not result in all your stuff on the iPad - the backup will).
    That should work - let us know how you get on...
    38551
    Chicago
    12
    ok so now that i have done some research and i read in a few forums that 4.3.5 is causing wifi to crash and that there is a bug glitch or what ever that is causing a connectivity problem so instead of upgrading to the 4.3.5 i think ill wait but i still want to restore to apple ios 4.3.3 how can i do that without automatically upgrading to 4.3.5 if my itunes version and my ios is already 4.3.3 can i just unjailbreak and stay on the current ios..
    14571
    603 times
    Sep 2010
    Troon, Scotland
    7,059
    I can assure you there is no bug in 4.3.5 which is causing wi-fi to crash. I don't know where you read that, but bear in mind there are 100M+ iDevice users, tens of millions of which will be on 4.3.5 by now. If there was a widespread problem with wifi on that or ANY firmware Apple would move fast to fix it. Unfortunately if you google "battery" or "wifi" problems with almost any firmware version you will get hits. There is always someone somewhere who has a problem. That's just the nature of the beast when you become so popular. Unless you see official widespread confirmation of an issue you shouldn't avoid any particular version, especially not 4.3.5 if that's what you want to install.
    Technically speaking 4.3.5 is feature identical to 4.3.3. It only has a couple of fixes to block jailbreaking and fix a vulnerability. The wireless / wifi code was not touched one iota, so if 4.3.5 has problems, so would 4.3.4 and 4.3.3...
    Hope that clarifies.
    iPhone5 32GB 6.1.2 (evasi0n) | iPhone4S 64GB 5.1.1 (absinthe) | iPhone4 32GB 7.0b (stock) | iPhone3G 16GB 3.1.3 (jbme) | iPod Classic 6G 160GB (stock) | AppleTV 2G 5.0.2 (seas0npass)
    7489
    126 times
    Jun 2010
    Sacramento, California
    14,962
    Quote Originally Posted by Madewomen2011 View Post
    Seriously? Never heard this one before.
    Marie ~
    Forum Rules. Please Read.
    appleforums.net
    38516
    18 times
    Seattle
    555
    f4780y, could the issue be with an entry on the host file? I ran into that problem before when I tried doing a restore and once I deleted them from the host file (I believe it was something like 'gs.apple.com' it restored fine... just a thought. OP, wait to hear back from f4780y on this before attempting it as I'm not positive and don't want your issue to get worse.
    iPad 2 64GB Wifi 5.1.1 jailbroken
    38551
    Chicago
    12
    First of all just want to say thanks for all ur help.. That shift restore worked wonderful..I was able to locate the file and upgrade very easily..oh by the way the posts I read about iOS 4.3.5 was actually on apple website in the forum community section I'll try to copy link..no way I would make it up it's putting no cash in my pocket actually these devices take out so I really could care less just passing on what I read.. I'm not the job guy so this doesn't stress me out at all. As long as my I-devices are working and updated I'm great.. But thank you guys for you help, I am currently un jail broken on 4.3 .5 thanks for your help.
  1. Restoring your ipad
    By Royceanator in forum iPad Help
    Last Post: 08-30-2011, 04:43 AM
  2. NEED HELP; restoring my ipad 2 for jailbreak
    By Legendaryatop in forum iPad Hacking
    Last Post: 08-11-2011, 07:52 PM
  3. Restoring my iPad from a backup
    By sundance2011 in forum iPad General Discussions
    Last Post: 03-24-2011, 04:54 PM
  4. ipad 3.2 not restoring 3.2.1
    By p3la in forum iPad Hacking
    Last Post: 08-07-2010, 01:18 PM
  5. Restoring iPad in Singapore
    By canshota in forum iPad Help
    Last Post: 06-17-2010, 10:05 PM
how to reset ipad to factory settings without itunes
how to restore ipad 2 to factory settings after jailbreak
how to restore ipad to factory settings without itunes
ipad will not restore after jailbreak
ipad wont restore after jailbreak
my ipad will not reset
my ipad wont reset
my ipad wont restore and update
my ipad wont restore factory settings
restore ipad to factory settings after jailbreak
