Unique problem on my Ipad 2...
This is a discussion on Unique problem on my Ipad 2... within the iPad Hacking forums, part of the Apple iPad Discussions category; Hi my JB Ipad 2 4.3.3 is showing very wierd symptoms that i cannot find any help from hours of reading. here goes, its not ...
Results 1 to 10 of 12
    93388
    Aug 2011
    Hi my JB Ipad 2 4.3.3 is showing very wierd symptoms that i cannot find any help from hours of reading. here goes, its not broken but almost like one..
    My ipad can reboot normally, but when it reboots, the lockscreen is missing the picture slideshow icon, and time. It reboots everytime i press winterboard, settings, sb settings, or most programs like whatsapp too. The icons are spread out far and wide, Everytime it reboots 10-20 times, it goes back to normal, and after a reboot, it does this again.
    I suspect it was a theme i downloaded and i uninstalled winterboard, sb settings, to try eliminate the issue but after 2-3 reboots, its comes back.
    My stock IOS is 4.3.3, but i cannot grab the SHSH using TU cos its too late. so it saves 4.3.5 and 5.0a/b/c, and Ifaith does not work on Ipad 2. I have openshh but i cannot get to the IP address on my ipad.
    I had once got into IT safe mode, and it helps as i can delete things and all ,but once it rebooted, back the the same problem. Anyone can teach me how to boot into safe mode? I have SB settings but i donot know the standard buttons to press or hold to boot into safe mode... i cannot find it anywhere on the web too.
    Anyone please help, or advice is very much appreciated.
    37823
    748 times
    Cranbrook, Kent, UK
    17,132
    I have moved this to the hacking forum where you may receive more appropriate assistance.
    67820
    113 times
    Jun 2011
    Lancashire, England.
    3,061
    Is this thread not the one you need??
    DFU Mode for Dummies
    64GB wifi ipad2 iOS 7.0.6 (Jailbroken using Evasi0n) : 120GB iPod Classic (Now in Apple heaven as I left it in my trouser pocket in the washing machine BOO HOO!!) : AppleTV 2G iOS 5.0.2 (Jailbroken using seas0npass): iPhone 4S 64GB iOS 7.0.6 (Stock, so I can stream Sky Go) : iMac 27 (Living The Apple Dream!!)
    67820
    113 times
    Jun 2011
    3,061
    Or do you mean recovery mode.......
    How To: Put your iPad into Recovery Mode
    14571
    632 times
    Sep 2010
    Troon, Scotland
    7,104
    The symptoms you describe are related to having installed a tweak or app which is not compatible with the iPad and was designed for the iPhone. Winterboard, SBSettings, etc. are NOT the culprits. They work fine on the iPad.
    You need to list out every application from Cydia which you have installed. It should be easy to spot which one is designed for iPhone only...
    To get into safe mode, bring up SBSettings and press "Power", and you will have an option for Safe Mode there...
    iPhone5 32GB 6.1.2 (evasi0n) | iPhone4S 64GB 5.1.1 (absinthe) | iPhone4 32GB 7.0b2 (stock) | iPhone3G 16GB 3.1.3 (jbme) | iPod Classic 6G 160GB (stock) | AppleTV 2G 5.0.2 (seas0npass)
    13576
    1447 times
    Aug 2010
    Western NY state (USA)
    11,054
    And please, until/unless we've exhausted all help for you, don't put the iPad into DFU mode or restore it!
    Sorry, TheRambler, but that's not good starting advice for someone with a jailbroken iPad2 with no iOS 4.3.3 SHSH blobs saved! He follows your advice, he loses his jailbreak - with no hope of going back.
    Let's try to solve the problem first ... and save the restore for the very end (as it WILL remove the jailbreak permanently).
    The best thing is to do as f4780y suggested - list your currently installed apps and we can see which one might be causing the problems.
    Thanks.
    83480
    3 times
    Jul 2011
    198
    Quote Originally Posted by Mickey330
    Thanks.
    So true. If this thread ever reaches 10+ pages, then get over it and restore. But never mention it as the first idea.
    My idea? Uninstall everything from Cydia, then install each one, one at a time. After each install, check your lockscreen if the picture frame has dissappeared. When it does, you know what has caused it.
    They say a car represents your personality. I have no car.
    67820
    113 times
    Jun 2011
    3,061
    My bad, sorry.
    I thought by putting those links he could read the info and decide for himself what to do.
    Also, if it's jail broken and he has Cydia apps running, why hasn't Cydia saved his blobs....or does that only happen if you tell TU to do that??
    13576
    1447 times
    Aug 2010
    11,054
    Just because you are jail broken and running iOS 4.3.3 doesn't mean you could save the blobs for that version. They are two separate events.
    For example, if you got an iPad yesterday, it could still be running 4.3.3 cause it's been on the shelf for a while. However, Apple stopped signing the blobs for that version almost a month ago, so there is no way to EVER save the blobs for that particular iPad (even though it is running iOS 4.3.3). Again, they are two different processes.
    Hope that makes better sense and clarifies how a person can be jailbroken on iOS 4.3.3, yet not have blobs saved in Cydia (or via TU).
    67820
    113 times
    Jun 2011
    3,061
    I understand that, the bit that never makes sense to me is this.........
    If you Jailbroke your iPad, you obviously had to do it whilst apple were signing 4.3.3 or you had your blobs saved. Now in the first case, apple were signing and you've jail broke......surely you would be well excited and searching through Cydia for different apps.....wouldn't this record your 4.3.3 blobs.
    I know this may sound daft, but that's what I thought happened.
    Forget this question....thought about it.....realised I'm daft.......pretend I didn't ask LOL
  1. Unique and Handmade iPad Cases?
    By KimbaKakes in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 05-21-2012, 05:51 AM
  2. Replies: 14
    Last Post: 05-30-2011, 08:21 AM
  3. UNIQUE PROBLEM WITH IPAD, can anyone help
    By sorabh_babs in forum iPad Help
    Last Post: 06-12-2010, 04:46 AM
  4. Unique use for iPad - reading the Bible in ASL
    By 4phun in forum iPad General Discussions
    Last Post: 05-08-2010, 11:00 PM
after ipad reboot icons are far apart
icons in ipad are too spread put
ipad apps spread out
ipad icons spread out
ipad icons spread out on ipad
ipad2 symptoms
jailbroken ipad icons spread out
missing picture frame settings ipad jailbreak
