Help! Problem installing sources in cydia!
This is a discussion on Help! Problem installing sources in cydia! within the iPad Hacking forums, part of the Apple iPad Discussions category; Hey I've been having a lot of problems adding new sources in cydia and can't figure out what to do. Ive been able to put ...
Closed Thread
Results 1 to 4 of 4
    iPad Enthusiast!
    42976
    Iowa
    43
    Hey I've been having a lot of problems adding new sources in cydia and can't figure out what to do. Ive been able to put a handful of sources in but any others simply just dont complete. In the attached screenshot it shows that the packages all loaded but then it just sits their for as long as it can before you push cancel. Any tips?
    Attached Thumbnails Attached Thumbnails Help! Problem installing sources in cydia!-image-2604529455.png
    14571
    596 times
    Sep 2010
    Troon, Scotland
    7,049
    Tip1 - Don't post a screenshot which betrays you are a pirate on a forum which has a strong anti-piracy stance. It does not encourage any of us to assist you.
    Tip2 - Unreliable non-standard repos are just that. Unreliable. If they don't finish loading it is usually because they are under too much pressure or the owners simply don't maintain / monitor the servers. There is nothing you can do about it other than contact them directly.
    Tip3 - Read the rules linked in my sig.
    iPad Enthusiast!
    42976
    Iowa
    43
    I never said I was pirating anything or condoning it. Idk what I would be pirating by showing my source screen. And I dont know why you cant help me at all :/ my friend just gave me a list of his sources on his iphone that said they all had really cool apps and tweaks so I was adding them all to make my cydia list bigger. Whats the deal?
    14571
    596 times
    Sep 2010
    Troon, Scotland
    7,049
    Ignorance is not an excuse. The second source in your list exists for one purpose only. To allow you to install apps and tweaks which enable you to steal software. When you add it to Cydia it gives you a warning to this effect.
    You were given 3 tips. All 3 are valid, and number 2 answers your question precisely, even if the other two are a bit facetious. I suggest you read them all again. It is because you are adding unreliable sources that you are having problems for the reasons stated.
    We don't support or condone piracy here. My point is that when you blatantly show us that you do, why should any of us feel motivated to help?
    Since that's a rhetorical question, I'll close the thread now to avoid opening this up to any further debate, which could be counterproductive.
  1. Finding new sources for Cydia
    By TheRambler in forum iPad Hacking
    Last Post: 07-14-2011, 11:43 AM
  2. Updated to 4.3.3 Cydia won't add sources!!
    By will89 in forum iPad Hacking
    Last Post: 06-16-2011, 04:56 PM
  3. Cydia iPad specific sources
    By sgtcasey in forum iPad Hacking
    Last Post: 04-24-2011, 08:16 PM
  4. Good Sources that don't come with Cydia?
    By Dahabi in forum iPad Hacking
    Last Post: 10-24-2010, 09:21 AM
  5. Cydia stuck at "Downloading Sources"
    By Generalgergles in forum iPad Hacking
    Last Post: 08-08-2010, 03:28 PM
adding cydia sources timeout
can't add sources in cydia
can't download sources on cydia
cannot add sources to cydia
cydia cant install sources
cydia sources timed out
cydia sources wont download
cydia sources wont install
having trouble adding sources to cydia
i can't a new sources in cydia
why can't i add source in cydia
why can't i install sources in cydia
