Problem regarding Winterboard themes and backgrounds
This is a discussion on Problem regarding Winterboard themes and backgrounds within the iPad Hacking forums, part of the Apple iPad Discussions category; Hi, I am running 4.3.3 jail broken on my iPad 1. I just downloaded the theme A I R from Cydia; however, like the other ...
Results 1 to 10 of 13
    80089
    Jul 2011
    43
    Hi, I am running 4.3.3 jail broken on my iPad 1. I just downloaded the theme A I R from Cydia; however, like the other themes I have downloaded from Cydia, the theme's lock screen and springboard backgrounds do not show up. So I have installed the theme but the backgrounds I had previously set from my photos have not changed. I would really appreciate any help.
    Thanks!
    Banned
    12904
    34 times
    Aug 2010
    Raleigh, NC USA
    3,655
    Some themes require you to enable separate parts like those through winterboard.
    13576
    743 times
    Aug 2010
    Western NY state (USA)
    9,265
    Or, take a look at your Winterboard settings (either via the icon or Settings).
    You should see a line titled "User Wallpaper" and "User Lock Background." Make sure those are unchecked.
    Let us know if that helped.
    80089
    Jul 2011
    43
    Both of them are unchecked. Thing is, this has happened to me with every theme I have ever used. Do I need to SSH into my phone to change anything to fix this? Thanks a lot for the help guys!
    iPad Addict
    27034
    5 times
    Dec 2010
    Gettysburg, Pa
    1,237
    You could have another tweak installed that could be overriding winterboard theme.
    Banned
    12904
    34 times
    Aug 2010
    Raleigh, NC USA
    3,655
    Post a screenshot of the list of themes in winter board.
    80089
    Jul 2011
    43
    Ok. I have attached a screenshot of my list of Cydia installations. Everything else about the theme seems to be just fine- the icons, status bar, etc. It's just the lockscreen and springboard wallpapers that will not change. Thanks again for the help guys!
    Attached Thumbnails Attached Thumbnails Problem regarding Winterboard themes and backgrounds-image-186289737.png   Problem regarding Winterboard themes and backgrounds-image-2194090652.png   Problem regarding Winterboard themes and backgrounds-image-1041419695.png   Problem regarding Winterboard themes and backgrounds-image-2598132553.png
    Banned
    12904
    34 times
    Aug 2010
    Raleigh, NC USA
    3,655
    I meant in winterboard. Like this:
    Attached Thumbnails Attached Thumbnails Problem regarding Winterboard themes and backgrounds-img_0017.png
    80089
    Jul 2011
    43
    Oh ok. I thought you meant of my Cydia installations as OUTL4W mentioned there could be a clash. Here is my winterboard screenshot then. Thanks!
    Attached Thumbnails Attached Thumbnails Problem regarding Winterboard themes and backgrounds-image-3445055559.png
    13576
    743 times
    Aug 2010
    9,265
    Heh. Google is my friend!
    I looked up the theme on Google and found this little note at the bottom of the developer's page:
    Note:
    As the theme wont set the wallpaper automatically I have attatched it to the bottom of this post or it can be found by navigating into the themes folder on your device with iFile and adding it to the photo album
    So, go into iFile where the theme is (var/stash/Themes.../A I R iPad.theme) and at the bottom are the four wallpapers that come with this theme. If you select one of the PNG files, you can open it right in iFile (use "Image Viewer").
    When the image opens, there's a folder icon with a down arrow in it at the center bottom of iFile's viewer. Pressing on that folder will save it to your Photo app. Then, you just have to go into Settings > Brightness & Wallpaper and select it for your home/lock screen (it'll be under Saved Photos).
    Hope that helps. And sorry if I told you how to use iFile when you may have already known. Just saves time...
  1. HOW TO - Change Folder Backgrounds
    By Svrdhd in forum Jailbreaking & Hacking Tutorials & How-To Guides
    Last Post: 02-05-2013, 08:59 AM
  2. Illustrated Backgrounds HD - now on appstore!
    By myraz in forum iPad Wallpapers
    Last Post: 09-09-2011, 11:30 AM
  3. Fire/EMS Backgrounds
    By JoshWx7 in forum iPad Wallpapers
    Last Post: 05-29-2011, 10:43 AM
  4. How to find ipad themes for winterboard?
    By pego99 in forum iPad Hacking
    Last Post: 05-01-2011, 05:56 PM
  5. Backgrounds Wallpaper Preview
    By Sonny Burnett in forum iPad Wallpapers
    Last Post: 10-08-2010, 10:07 PM
cydia themes not working
fix winterboard theme wallpapers from showing
how to fix winterboard theme problem
themes not showing up in winterboard
user lock background winterboard
wallpapers not loading when using themes on winterboard
why are my winterboard themes not working
winterboard theme not working
winterboard theme wallpaper not working
winterboard themes not changing
winterboard themes not installing wallpaper
