White dot help
This is a discussion on White dot help within the iPad Hacking forums, part of the Apple iPad Discussions category; I updated several Cydia apps and now I have a white dot that's following me around when I touch my screen. Please help me figure ...
Results 1 to 10 of 12
Thread: White dot help
    44686
    Cincinnati, OH
    62
    I updated several Cydia apps and now I have a white dot that's following me around when I touch my screen. Please help me figure out how to turn it off.
    Sent from my iPad 2 using iPF
    ~Cincy
    14571
    595 times
    Sep 2010
    Troon, Scotland
    7,046
    Did you install DisplayRecorder and set it to always show the screen touches? If so, set it to off in the Settings app.
    44686
    Cincinnati, OH
    62
    No I have adblocker, btlogo, btstack, cydelete, display out, full force, safari full screen, infinifolders, isocialshare, retina pad and winter board.
    ~Cincy
    44686
    Cincinnati, OH
    62
    Please, can anyone help me? This is very annoying. Anytime that I touch my iPad, I get a white dot under my fingers. It's recognizing where I am touching and placing a marker there. I can touch it with one finger or ten and I will get as many white dots as I place fingers on the screen.
    ~Cincy
    iPad Enthusiast!
    63426
    Jun 2011
    56
    Start uninstalling apps starting with the last one you remember installing. Respring after each uninstall and test.
    82471
    Jul 2011
    Surabaya
    Quote Originally Posted by ALcH3Mi5T
    How to uninstall program or application ....
    116 times
    15,249
    You can simply press on any icon until they start to jiggle. The touch the upper left hand corner of the app that you want to delete. You'll be asked to confirm that you want to delete and, if you accept, it's gone.
    13576
    743 times
    Aug 2010
    Western NY state (USA)
    9,262
    To uninstall Cydia apps, you need to go to the Install tab on Cydia, select the tweak and when it open, select "Remove" under the Modify button (upper right hand side).
    I see you have CyDelete, so some Cydia apps can be deleted with the hold/wiggle method. However, some Cydia tweaks don't have icons to hold/wiggle, even with CyDelete - so you have to go to Cydia.
    Oh, and in case ALcH3Mi5T's directions weren't clear, you want to uninstall/reboot/reinstall your Cydia apps/tweaks, not the App Store ones. That's because your problem is, more than likely, caused by something you did that's connected with your jail break.
    Try uninstalling btlogo, btstack, cydelete, display out, full force, or isocialshare because I have the other apps you listed currently installed and they are running on my iPad with no trouble. I'm thinking it might be btlogo, btstack or isocialshare - mainly because I've run the other apps with no trouble.
    Good luck and let us know how you get on.
    14976
    Sep 2010
    37
    I have the same issue with the white dot/circle
    I have found that Displayout is the culprit, if uninstall the programme the problem goes away, if i reinstall the white dot issue comes back
    To stop the issue go to, Settings/Displayout and set 'Show taps' to Never
    84027
    Aug 2011
    Taps
    Just go to settings, Display Out, Show Taps, select never and your done.
  1. What do you have, white or black.
    By Martinm in forum iPad 2 Forum
    Last Post: 04-08-2011, 10:23 PM
  2. Why WHITE?
    By droid2mac in forum iPad 2 Forum
    Last Post: 04-05-2011, 08:50 PM
  3. My 32G white came in at Best Buy but...
    By krause28 in forum iPad 2 Forum
    Last Post: 04-03-2011, 10:34 AM
  4. Black or White?
    By yvrgal in forum iPad 2 Forum
    Last Post: 03-18-2011, 09:11 AM
  5. White or black?
    By graywolf in forum iPad 2 Forum
    Last Post: 03-13-2011, 06:14 PM
how do i get the options white dot off my iphone scree
how do i take the white dot of the exp8 touch screen?
how to get rid of dot on iphone
how to get rid of the dot on iphone
how to get rid of white dot on iphone
how to get the white dot on the side of screen on the iphonr
how to get white dot on iphone
how to remove white dot on iphone
how to remove white dot on iphone screen
how to turn off the iphone dot
remove white dot navigation on ipad
