Results 1 to 7 of 7
    82170
    Jul 2011
    Recovery Loop - need help
    Hey guys.
    I've got my Ipad stuck in a recovery loop every time i reboot or shut down, although it's on 4.3.3, which is supposed to be untethered. I used redsn0w and downgraded from 4.3.4, since I wanted an untethered jailbreak.
    However, now I am able to use the system just fine (even downloaded some apps from Cydia), but the issue with having to plug it to a computer and use the "just boot tethered right now" option in redsn0w every time following a reboot is quite annoying.
    TinyUbrella's "Exit Recovery" button is greyed out and can't be used. Also, the "Fix Recovery" option doesn't produce a result although it's available.
    I went through a lot to be at this stage and would be happy to describe it. However, if you've got any suggestions at this point this would be greatly appreciated.
    13576
    803 times
    Aug 2010
    Western NY state (USA)
    9,454
    Since you talked about using redsn0w, I can assume you've got an iPad1? And that you've saved the SHSH blobs for iOS 4.3.3?
    If so, I'd suggest using a clean version of iOS 4.3.3 (download link here: Official Apple IOS Firmware Download Links for iPad), putting the iPad into DFU mode and restore to that [clean] version (sticky here: DFU Mode for Dummies) and then re-jailbreak using JailbreakMe 3.0, which is an untethered jailbreak.
    Let us know how you get on.
    15357
    Sep 2010
    Germany
    102
    I had the same issue last week.
    I did the upgrade on a windows system and my iPad went into the loop.
    Luckily, there was an Apple Store nearby and with a Mac they managed to restore it in next to no time.
    They told me that this happens on Windows systems with certain virus-scanners and advised me todisable the virus scanner while updating the iPad.
    So, if your computer runs unde Windows, disable the virus scanner and then try again.
    82170
    Jul 2011
    Many thanks for the quick replies!
    Using iFaith I got the SHSH blobs from the currently unusable iPad 1 with 4.3.3 on it. Then I created a *signed* .ipsw using the .ipsw Mickey330 pointed to combined with my newly acquired blobs.
    Everything seemed fine and the device was restoring fine until an error 37 popped up. Then I tried again, disabling all anti-virus software and firewalls as Markk pointed out but this time the restoration process went much faster eventually terminating with an "error 1600". Even after a restart there was no change.
    Even if I try with the completely clean freshly downloaded 4.3.3 .ipsw (without compiling it with any blobs) I still get error 3194.
    I'm completely stuck and have no idea what to do
    *I'm running Windows 7; iPad 1 3g 32Gb and atm I am stuck with error 1600 in iTunes*
    13576
    803 times
    Aug 2010
    9,454
    What are you using to create that "signed" IPSW file? Snowbreeze? I ask that because that's the only thing that comes up when I Google that error code (on this forum). If you are, let me quote f4780y here:
    Error 1600 indicates you are possibly not using the sn0wbreeze tool to put your iPad into pwnd DFU mode before you install the custom firmware. You MUST use the iREB tool in sn0wbreeze. You can't just put the iPad into DFU mode yourself. Can you confirm that at the end, sn0wbreeze tells you it was successful and you should now restore in iTunes? Only if the tool tells you you are in pwnd DFU mode should you proceed.
    The above came from this sticky: TUTORIAL - Jailbreak iPad1 with sn0wbreeze
    ---- OR ---
    Try this (post #5) from this thread: http://www.ipadforums.net/ipad-hacki...aked-ipad.html
    As you'll note, I'm not afraid to use f4780y's words. If it works, yeah?
    So, did either help?
    82170
    Jul 2011
    Cheers, Marilyn!
    Indeed, I used iFaith, as mentioned above, which is part of the sno0breeze package (by the same creator). Your comment pointed me in the right direction and now I've essentially eliminated 1600 and it does not appear anymore, because I prepare the iPad by putting it in pwned DFU mode.
    However, ultimately, error 37 comes up invariably every time with every .ipsw (custom "signed" or original) and on every computer I tried it on (all on Win).
    I understand it's related to software interference but I'm not able to get past this (one of computers I tried it on was a fresh installation of WinXP with firewall turned off and no anti-virus soft).
    So, basically now I'm stuck in an error 37 loop in addition to the recovery loop At least fate's got a sense of irony
    82170
    Jul 2011
    Btw, is there a way to convert iFaith's SHSH blobs to a format usable by Tiny Umbrella, so that I can install a clean 4.3.3.
    *Now, the only 4.3.3 blobs I've got are from iFaith*
  1. DFU Infinite Loop
    By awatt in forum iPad Hacking
    Last Post: 07-25-2011, 06:58 AM
  2. iPad 2 4.3.3 recovery loop
    By DontUnderstandMyIpad in forum iPad Hacking
    Last Post: 07-17-2011, 09:27 PM
  3. iPad1 stuck in recovery loop FW 4.3.3
    By maim in forum iPad Hacking
    Last Post: 06-03-2011, 12:34 PM
  4. Dfu loop?? :(
    By Gamingipad in forum iPad Hacking
    Last Post: 05-22-2011, 07:46 AM
  5. Griffin Loop...what do you think?
    By GiPad in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 07-16-2010, 10:59 PM
convert ifaith to shsh
convert shsh to ifaith
error 37 ifaith
ifaith error 37
ifaith restore error 37
ipad error 37 fix
ipad in recovery loop
ipad recovery loop
ipad restore loop
ipad restore loop fix
recovery loop ipad
restore loop
