Battery drain?
This is a discussion on Battery drain? within the iPad Hacking forums, part of the Apple iPad Discussions category; After jailbreaking the iPad 2, it seems the battery is draining much faster than before. Anyone experiencing the same? Can I relate this to SBsetting?...
Results 1 to 9 of 9
Thread: Battery drain?
    64088
    Jun 2011
    the Netherlands
    17
    Battery drain?
    42714
    95
    I've been happy with the battery performance since the jb. I expected it to diminish, but it seems every bit as good (or slightly better, if that's possible) then before. It's possible the perception of better is based on how much more I'm enjoying it since the jb.
    74222
    Jul 2011
    Cave Creek, AZ
    19
    Quote Originally Posted by Tokkie View Post
    I think I am noticing the same as well
    64088
    Jun 2011
    the Netherlands
    17
    I just uninstalled SBsetting and will see how it goes. Will keep you posted about this matter.
    67820
    109 times
    Jun 2011
    Lancashire, England.
    3,043
    Yeah definitely going quicker, but then we are doing a lot more than we were previously!!
    64GB wifi ipad2 iOS 6.1.2 (Jailbroken using Evasi0n) : 120GB iPod Classic (Filled with Rock Classics!) : AppleTV 2G iOS 5.0.2 (Jailbroken using seas0npass) : iPhone 3GS 16gb iOS 6.1.2 (Jailbroken using Evasi0n) : iPhone 3GS 32gb iOS 6.1.2 (My Rambling Tool is now Jailbroken using Evasi0n) : iPhone 4 16GB iOS 6.1.2 (Jailbroken using Evasi0n) : iPhone 4S 64GB iOS 6.1.3 (Stock, so I can stream Sky Go)
    62857
    Jun 2011
    Orebro, Sweden
    170
    I'm eagerly awaits Tokkies report! Have noticed a more rapid drainage of battery myself. At least I think so, considering the truthfulness of above post...
    I have a JB-ed iPad2 (32Gb/WiFi/6.1.2), and I'm not afraid to use it!
    58885
    May 2011
    Toronto
    27
    I am definitively experiencing a faster battery drain since jailbreaking. I do realize that we are probably playing with are ipads more now and also respringing a lot more. When compared to my jailbroken 3rd gen ipod touch there is a much a faster drain.
    48467
    Any update on the results for uninstalling sbsettings?
    58885
    May 2011
    Toronto
    27
    My battery life has seemed to have stabilized now. I guess I was playing around with it a lot and also I have uninstalled the apps I don't use or need.
  1. Battery drain is it Safari?
    By Archer in forum iPad General Discussions
    Last Post: 06-19-2011, 01:03 PM
  2. Battery drain query.
    By ipadsi in forum iPad Hacking
    Last Post: 04-07-2011, 10:07 AM
  3. tweaks that cause battery drain
    By beatlejohn in forum iPad Hacking
    Last Post: 02-18-2011, 10:20 AM
  4. Battery Drain??.
    By David Vice in forum iPad FAQ
    Last Post: 02-06-2011, 03:05 AM
  5. How to drain battery
    By Kim in forum iPad Help
    Last Post: 10-29-2010, 05:23 PM
battery drains after sbsettings
does jailbreak drains ipod battery life?
does jailbreaking drain battery
does sbsetting drain battery
does sbsettings drain battery
sbsetings battery drain
sbsetting battery drain
sbsetting drains iphone 4 battery life
sbsettings battery drain
sbsettings battery drain ipad
sbsettings drain battery ipad 3
sbsettings ipad 2 can help draining
