Jailbreak problem!
This is a discussion on Jailbreak problem! within the iPad Hacking forums, part of the Apple iPad Discussions category; So i was jailbroken on 4.3.0. I was told i needed to be on 4.3.3. So i updated my ipad2 64gb 3g and cydia loads ...
Closed Thread
Results 1 to 7 of 7
    47632
    Phoenix!
    Jailbreak problem!
    So i was jailbroken on 4.3.0. I was told i needed to be on 4.3.3. So i updated my ipad2 64gb 3g and cydia loads but when it goes to install it disappears! What have i done wrong?
    38516
    18 times
    Seattle
    555
    Some folks had to reboot their iPad, hold down the power and home button until the iPad shuts off. Wait a few seconds then turn it back on and see if that fixes your issue.
    42140
    7 times
    Columbus Ohio
    369
    Quote Originally Posted by Thedivineguy
    It's because you were jailbroken and updated instead of restoring. When you just update, it still leaves parts of jailbreak files in your system. I had the same exact problem. Cydia would start downloading then a little bit after half way it would say installing and then disappear. All you need to do is Restore to 4.3.3 and your all good! You can even restore from backup to keep your pics and settings!
    iLoveMyiPad2!
    72434
    Jul 2011
    UK
    7
    I had this problem. What i did was put the ipad into recovery mode. Did a software re install. Then i jailbroke and installed Cydia BEFORE re installing my backup. Job done.
    278463
    Feb 2013
    my ipad 2 is jailbreaked ios6.1. everything was running smoothly still is untill i went onto a piracy site and downloaded some apps. i synced them on my ipad, all went smooth apps work perfectly but now cydia and appstore isnt opening properly. ive taken screenshots, they open but the screen is so small and i cant press anything.. please help. is there a way of fixing the problem without having to start again? Jailbreak problem!-photo.png please reply asap..
    Moderation notice: This post has been edited by the iPadForums staff in accordance with theForum Rules Removed piracy link
    Moderator
    131244
    1426 times
    Dec 2011
    Regina,Canada
    18,550
    Quote Originally Posted by ronnie1234
    my ipad 2 is jailbreaked ios6.1. everything was running smoothly still is untill i went onto a piracy site and downloaded some apps. i synced them on my ipad, all went smooth apps work perfectly but now cydia and appstore isnt opening properly. ive taken screenshots, they open but the screen is so small and i cant press anything.. please help. is there a way of fixing the problem without having to start again? <img src="http://www.ipadforums.net/attachment.php?attachmentid=35581"/> please reply asap..
    You are a thief and a pirate;
    Here's all the advice you will receive. Remove the apps you downloaded from that piracy site and your iPad should start working properly.
    Stay legal, pay for your apps.
    37823
    748 times
    Cranbrook, Kent, UK
    17,132
    And to add, as this is an old thread which you have posted in to discuss piracy........we will now close this thread.
  1. iPad- Redsn0w Jailbreak charging problem
    By Takeover in forum iPad Hacking
    Last Post: 05-13-2011, 02:13 PM
  2. iBooks FIX iOS 4.2.1 Jailbreak DRM Problem
    Last Post: 02-17-2011, 03:00 AM
  3. Anyone had this problem after jailbreak?
    By RudyL90 in forum iPad Hacking
    Last Post: 01-25-2011, 01:33 PM
  4. Safari Problem after removing Jailbreak.
    By cam in forum iPad Hacking
    Last Post: 12-27-2010, 04:55 PM
  5. Replies: 6
    Last Post: 09-26-2010, 12:02 PM
halfway problem install jailbreak ipad 2
ipad 2 jailbreak problems
ipad 2jail break provlems
ipad 4.3.0 jailbreak
ipad jailbreak problems
ipad problems with jailbreak
jailbreak
jailbreak ipad intenet problems
jailbreak ipad problem
problem of jailbreak ipad
