Help JB...iPad1 running 4.3.3_8J2
This is a discussion on Help JB...iPad1 running 4.3.3_8J2 within the iPad Hacking forums, part of the Apple iPad Discussions category; So I may be an idiot, but on my stock iPad1, under "about", it says my iPad is on 4.3.3 (8J2). I've tried using Snowbreeze ...
Results 1 to 10 of 11
    70290
    Jun 2011
    Oc
    So I may be an idiot, but on my stock iPad1, under "about", it says my iPad is on 4.3.3 (8J2). I've tried using Snowbreeze 2.7 with iPad1,1_4.3.3_8J3_Restore.ipsw, and get a firmware not compatible error during the "shift+Restore" part. I've tried using Redsn0w rc16 and rc18, and it froze up during the limera1n exploit. I've tried both Redsn0w and Snowbreeze MANY times each. I'm on a Win7 box, tried it in XPSP2 compatibility, without XPSP2 compatibility. Tried setting the affinity, without setting affinity. I've tried the same processes above over and over on my WinXP box, with the same problems and the same compatibility issues.
    I would have to think that the problem lies within this 8J2 vs 8J3 difference, When I do a standard iTunes restore, 4.3.3 8J2 is what it gives me. Every link i have found on the internet for iPad1 is for 4.3.3 8J3. I have noticed that the os for the iPad2 is 4.3.3 8J2. Did iTunes put the iPad2 OS on mu iPad1?
    Please help.
    Banned
    12904
    35 times
    Aug 2010
    Raleigh, NC USA
    3,655
    iTunes wouldn't put the wrong os on there. In snow breeze and redsnow, the software you select, is it the same one iTunes used to update the iPad? So did you select the software in user/appdata/roaming/apple computer/iTunes/iPad software updates? Or did you download the software from the Internet?
    70290
    Jun 2011
    Oc
    The firmware that is in the iPad right now was put on there through iTunes, and is the official firmware from apple, by just clicking restore...not through a shift+restore. Like I said though, on the about screen on the iPad, the version does say 4.3.3 (8J2), which has me really confused..The firmware I tried using was linked to this forum. In none of the tutorials did is say to use the firmware under user/appdata/roaming/apple computer/iTunes/iPad software updates. All tutorials, even the one on this forum just say to download 4.3.3 on "this link".
    70290
    Jun 2011
    Oc
    OK...so now I'm really going to sound like a rookie, but where do I find the path that you referred to?
    14571
    632 times
    Sep 2010
    Troon, Scotland
    7,104
    The firmware designation for the 4.3.3 download for iPad1 is 8J3. All other devices are 8J2.
    I've never heard of any iPad1 having a 8J2 version installed, however for the avoidance of doubt it is not possible for iTunes to have installed the iPad2 firmware on your device. It simply would not install or boot. It's not a case that it would be buggy. It simply could not run. Entirely the wrong hardware.
    I appreciate you say that you tried the compatibility settings as well as affinity etc., however the problems you mentioned at the start sound like exactly those issues. If iTunes would not allow you to restore the sn0wbreeze firmware it means the iReb tool did not put your device into pwnd DFU mode as it was supposed to. This only happens when the app isn't running with the right compatibility or admin privileges in my experience. You should not have to do anything special on Windows XP. I would suggest you try it again a few times. Does sn0wbreeze tell you it was successful in putting the device into pwnd DFU mode?
    iPhone5 32GB 6.1.2 (evasi0n) | iPhone4S 64GB 5.1.1 (absinthe) | iPhone4 32GB 7.0b2 (stock) | iPhone3G 16GB 3.1.3 (jbme) | iPod Classic 6G 160GB (stock) | AppleTV 2G 5.0.2 (seas0npass)
    iPad Master!
    9624
    Jul 2010
    293
    I just checked my iPad 2 64gb Wifi and it says 4.3.3(8J2) on it..is that Ok as far as me being able to jailbreak it when the jailbreak DOES come out..I had no idea I even had to look at something like that LOL.
    14571
    632 times
    Sep 2010
    Troon, Scotland
    7,104
    You don't. IMHO it is a complete red herring.
    70290
    Jun 2011
    Oc
    I just uploaded a picture from the about screen on my iPad1 showing that it is 4.3.3 8J2...I followed redsn0w and snowbreeze instructions exactly.
    Attached Thumbnails Attached Thumbnails Help JB...iPad1 running 4.3.3_8J2-2011-06-26_13-34-39_601.jpg
    14571
    632 times
    Sep 2010
    Troon, Scotland
    7,104
    Quote Originally Posted by Needz View Post
    OK Needz, but then I need to call you on the other glaring problem.
    Model Number MC769LL
    This is an iPad2 Model number. It has NEVER been an iPad1, and you CANNOT Jailbreak an iPad2.
    If you want to check, you can buy it at Amazon - [ame]http://www.amazon.com/Apple-MC769LL-Tablet-Black-NEWEST/dp/B0013FRNKG[/ame]
    Banned
    12904
    35 times
    Aug 2010
    Raleigh, NC USA
    3,655
    Quote Originally Posted by f4780y
    I would have never guessed! Dude, if you were trying to fool us, you did!
  1. Ipad1
    By kimimcnam in forum iPad Help
    Last Post: 06-17-2011, 04:53 PM
  2. I cannot ssh into my ipad1
    By papelboyh1 in forum iPad Hacking
    Last Post: 06-11-2011, 07:44 AM
  3. will ipad1 die?
    By benross29 in forum New Member Introductions - Site Assistance
    Last Post: 04-22-2011, 12:33 PM
  4. ipad1
    By supersteve1 in forum iPad 2 Forum
    Last Post: 03-28-2011, 08:12 AM
  5. ipad1
    Last Post: 03-24-2011, 09:38 PM
8j3 vs 8j2 ipsw
ipad 2 mc769ll jailbreak
ipad model mc769ll jailbreak
ipad model mc77066 version 4.3.3 (8j2)
jailbreak ipad mc769ll
jailbreak mc769ll
mc769ll jailbreak
what does (8j2) mean behind your ipad version
Tags for this Thread
