need help restoring jb to stock
This is a discussion on need help restoring jb to stock within the iPad Hacking forums, part of the Apple iPad Discussions category; i cant connect my ipad to itunes nor can i charge it anymore. the connector is messed up. didnt do anything to it, just plugged ...
Results 1 to 7 of 7
    37431
    so cal
    25
    i cant connect my ipad to itunes nor can i charge it anymore. the connector is messed up. didnt do anything to it, just plugged it in and left it alone for a a day. i came back and saw it was at 50% battery. so i plugged it to my computer and nothing. i wiggle it around still nothing. now i cant take it in to get it fix. i read some where some one stated about ftp into it and removing files. i have no idea what files to remove in order to restore it back. i dont want to play with it since i cant charge it and i dont want it to be be completely dead before i can restore it. any help would be appreciated.
    iPad Addict
    27034
    5 times
    Dec 2010
    Gettysburg, Pa
    1,237
    Quote Originally Posted by ntrddragn
    Have you tried a differant 30pin to USB connector?
    Have a read here:
    http://www.ipadforums.net/ipad-hacki...3-warning.html
    But if all else fails and still having trouble.....
    On ipad
    Settings
    General
    Reset
    Erase all content and settings...
    14571
    596 times
    Sep 2010
    Troon, Scotland
    7,049
    Sorry to hear your connector is messed up. I am assuming you mean the connector on the iPad and not just that the cable is broken? If the connector on the iPad is broken you can never restore it. Suggest you test it out by connecting it to the wall charger, not the USB on your computer.
    If it will not charge, then you absolutely should just let the battery die. Turn the brightness up to max and start watching a movie or some other power hungry operation. Then once it is dead, that is it. You can return it to Apple for repair. They will not try and fix the connector and send you back the same unit. You will get a replacement refurb. They will not find out in this scenario that you were jailbroken, unless you are mistaken that the port is broken and they do manage to charge it. That's why you need to double check with different cable and using the wall charger.
    37431
    so cal
    25
    Thanks for the replies, I was premature in my post. :/ I turns out it was a bad cord. I went n got a new cord and plugged it into the wall charger and now it's charging. Man, a bad cord after three months. Great china built quality there. LOL
    37431
    so cal
    25
    So now my question would be, should i be able to exchange the cord down at the apple store? And do i need to take the ipad and cord or just the cord?
    14571
    596 times
    Sep 2010
    Troon, Scotland
    7,049
    I would take the cord down by itself. They have plenty of gear they can test it with... I"m sure if it is faulty they will just give you another, as long as the genius is having a good day!
    35810
    Feb 2011
    Philadelphia
    13
    They gave me new cord with no questions. Actually volunteered with no request. I just said I needed to buy new cord because old one broke. They handed me a new one.
  1. Restoring
    By AppleAlias3 in forum iPad Help
    Last Post: 05-28-2011, 01:12 PM
  2. Restoring Itunes Help!!!
    By j0yful in forum iPad Help
    Last Post: 05-06-2011, 07:57 AM
  3. Restoring but keeping 4.2.1
    By Drizz in forum iPad Hacking
    Last Post: 04-09-2011, 10:36 AM
  4. Keeping track of iPad stock -- its in stock at Walmart
    By justed in forum iPad General Discussions
    Last Post: 11-12-2010, 12:25 PM
  5. ipad 3.2 not restoring 3.2.1
    By p3la in forum iPad Hacking
    Last Post: 08-07-2010, 01:18 PM
restore jb ipad
