tweaks that cause battery drain
This is a discussion on tweaks that cause battery drain within the iPad Hacking forums, part of the Apple iPad Discussions category; im new to jb and was just wondering of certain tweaks or apps that cause battery drain (apart from animated wallpapers lol thats obvious) ive ...
Results 1 to 9 of 9
    18525
    Oct 2010
    30
    ive been using Ifile and my camara connection kit to watch movies off my memory cards for example does that cause more drain than watching it straight off the ipad memory?
    ive also changed almost everything on my lockscreen and home screens. my wifi bar colours battery colours all that sort of thing does that change any battery issues?
    any other things to watch out for would be good to know. thanks guys
    Banned
    10565
    16 times
    Jul 2010
    Va
    1,251
    Quote Originally Posted by beatlejohn View Post
    Good questions, id like to know also. Id figure having light colored wallpapers or backgrounds use more battery. I read somewhere that having darker themes, wallpapers or whtever will drain battery less.
    I use anesthetic wood winterboard theme and have noticed my battery doesnt drain as fast. Lasts alot longer. Its a dark theme, simple n cool. Little stuff like wifi bar colors or whatever shouldnt effect battery hardly. Autumn leaves hd lock screen theme is cool also. Lock screen shows animated leaves falling and has 2 widgets also, time and calender. Lock screen theme shouldnt affect battery as it only stays up a few seconds unless u have ipad set for password lock, like i do.
    18525
    Oct 2010
    30
    heres my ipad at the moment
    theres a scary laugh sound when i unlock it. apart from that no other custom sounds.
    also running Ifile, winterboard, gridlock, pkgbackup, mask for the icons. my background and icons are fairly dark too so i guess theres nothing really to change the battery usage. i havent had any issues by the way i was just curious of things that might affect battery use. i always have my brightness all the way down unless im showing someone something and need to turn it up. i can see it just fine on the lowest setting. also has anyone noticed the brightness only changes when u get about half way up the slider anyway? i tested it last night. maybe its the wallpaper im running and doesnt show up till then. might be different for other wallpapers??
    23194
    Dec 2010
    Ct
    14
    ^ I love your theme mind telling me which one it is? The greenposion one I tried was not like urs!
    16G wifi JB redsnow. Same on iPhone 4!!! I couldn't live without my apple toys
    18525
    Oct 2010
    30
    thanks glad u like it. i just found the wallpaper online. found another theme that i liked certain parts of. like the dock and the status bar outline. it was actually a blue theme i cant remember wat it was called. so i just changed the colours of the
    certain things i wanted to change and made my theme.
    the icons are glass orb ones i used gridlock to place the icons and i used mask to change and the icon shapes and colour the icons. pretty basic stuff really. the slider switches are just from a greenpoison theme and i added them into mine replacing my stock sliders.
    14571
    596 times
    Sep 2010
    Troon, Scotland
    7,049
    Please stop the madness in thinking that a light theme will have appreciably more battery drain than a dark one. It wont. I promise you.
    Backlight brightness will absoutely have the most significant effect, so keeping it low is good, but dont worry about the colour scheme in the slightest!
    Banned
    10565
    16 times
    Jul 2010
    Va
    1,251
    Quote Originally Posted by f4780y View Post
    Gotcha! Lol
    34154
    Feb 2011
    20
    Yup, regardless of a black or white theme, the pixels still have to be assigned an RGB value and display it, so it makes no difference in what color is actually displayed.
    31695
    US
    8
    Quote Originally Posted by kryptykk View Post
    Although this does sound accurate, however I have not witnessed this.
    I use Night Stand (clock for ipad) ..
    if I use LCD setting (black background with orange LED) and leave it running all night from a 100% charge, I'll wake up and it is at ~48% full
    if I use MILK (white background) and leave it running all night, I'll wake up with ~25%
  1. iPad Battery Drain
    By SallySparrow in forum iPad General Discussions
    Last Post: 04-26-2013, 07:00 AM
  2. Jailbroken iPad (4.2.1) not rebooting after battery drain
    By radumarinescu in forum iPad Hacking
    Last Post: 06-17-2011, 09:59 AM
  3. Battery Drain??.
    By David Vice in forum iPad FAQ
    Last Post: 02-06-2011, 03:05 AM
  4. How to drain battery
    By Kim in forum iPad Help
    Last Post: 10-29-2010, 05:23 PM
  5. Apps That Drain Your Battery Faster
    Last Post: 09-29-2010, 11:09 AM
cause of battery drain of ipad
do iphone themes drain battery
do themes drain battery
do themes drain battery iphone
does rising bars lockscreen theme kill battery faster iphone
does winterboard drain battery
html lockscreens battery issue
ifile battery drain
iphone theme battery drain
winterboard battery drain
winterboard themes drain battery?
