Results 1 to 6 of 6
    31907
    Feb 2011
    Under my bed
    Question Problem with retinapad and reboot
    Hello m8's, first post
    I really want to install and enjoy retinapad on my ipad 4.2.1 but when i try to install retinapad i have to reboot.
    When i reboot it freezes at the apple logo and i have to connect to itunes and return to normal un-JB state. That means I loose everything and have to re-do the jailbreak and install all my cydia stuff again, wich sucks.
    I think it could have something to do with my jailbreak since it's only tethered.
    Does anyone know a way to install retinapad on a tethered 4.2.1 ipad without haveing to reboot, or anohter way to make retinapad work
    14571
    603 times
    Sep 2010
    Troon, Scotland
    7,059
    You need to reboot the iPad in a TETHERED state. To do that you rerun redsn0w and choose the "just boot tethered now" option.
    You won't be able to turn your iPad OFF but just follow the instructions on screen exactly as if it was turned off. The iPad will reboot jailbroken and everything will be fine.
    iPhone5 32GB 6.1.2 (evasi0n) | iPhone4S 64GB 5.1.1 (absinthe) | iPhone4 32GB 7.0b (stock) | iPhone3G 16GB 3.1.3 (jbme) | iPod Classic 6G 160GB (stock) | AppleTV 2G 5.0.2 (seas0npass)
    31907
    Feb 2011
    Under my bed
    Thank you good sir
    So just to be sure, when retinapad installed from cydia and it pops up with the message "reboot", i'll just have to reboot tethered like i use to do, just without turning the ipad off ?
    14571
    603 times
    Sep 2010
    Troon, Scotland
    7,059
    Yes, OR you could actually just ignore the reboot button in Cydia when it appears and proceed immediately as follows...
    1. Plug in the dock cable and connect it to your PC (shut iTunes if you have it configured to start).
    2. With cydia still showing the reboot message, Hold down the power key until the slide to turn off bar comes up and turn off the iPad...
    3. Start redsn0w, and follow it through selecting the "just boot tethered now" option and following the instructions on screen.
    4. Voila!
    31907
    Feb 2011
    Under my bed
    thank you a ton
    you have helped me alot !
    14571
    603 times
    Sep 2010
    Troon, Scotland
    7,059
    Quote Originally Posted by Tesoo View Post
    thank you a ton
    You are very welcome.
  1. Always have to reboot
    By John3596 in forum iPad Help
    Last Post: 02-12-2012, 06:03 PM
  2. Replies: 0
    Last Post: 01-01-2011, 02:16 PM
  3. will hiding icons in sbs cause a reboot?
    By Dr.Gee in forum iPad Hacking
    Last Post: 12-09-2010, 10:48 AM
  4. Reboot/respiring.....definitions?
    Last Post: 12-07-2010, 01:31 PM
  5. Replies: 7
    Last Post: 05-31-2010, 07:02 AM
error retinapad
install errorrs ipad retinapad
problema instalar retinapad
retina pad bug
retina pad error
retina pad error when installing
retinapad bug
retinapad error
retinapad glitch
retinapad problem
retinapad wont install
where can i get my ipad power button fixed
