Jailbroken iPad (4.2.1) not rebooting after battery drain
This is a discussion on Jailbroken iPad (4.2.1) not rebooting after battery drain within the iPad Hacking forums, part of the Apple iPad Discussions category; Originally Posted by chixta
Hi - I have exactley the same problem, iPad keeps resetting, cannot charge etc. I do not know what Jailbreak Program ...
chixta
Hi - I have exactley the same problem, iPad keeps resetting, cannot charge etc. I do not know what Jailbreak Program I have installed though (this was already on when I brought it). I have Cydia and ***** EDIT ***** but I do not have the Redsn0w or Greenp0ison logo on boot up so this may not be the Jailbreak I have. Because of this, I have not worked through the fix suggested, only the resets and all other advice first but with no joy.
I am reluctant to do a restore via iTunes as I do not want to lose the Jailbroken Apps/data and have to jailbreak myself afterwards, but if this is the only way then I shall have to.
I am very much in distrss and call on you all for your advice pleaseeeee!!!
Chixta
Don't get sidetracked by this old discussion. It has nothing to do with the current situation you find yourself in. The above was mostly related to a tethered jailbreak, which you don't have.
Try the steps I outlined in your other thread, and we'll see if we can get you back up and working. OK?
Oh, and Don't be a Pirate!
06-11-2011 10:19 AM
iPad Enthusiast!
DoctorTim
To the idiots on various boards claiming that the jailbreak doesn't affect charging: Umm, you're idiots. If the battery is dead multiple people report that tethered iPad will not take a charge. This is a jailbreak issue. My iPad has entered this state previous to my iOS4 jailbreak without any issues. This only started after tethered jailbreak.
I think what you mean is: this is a 'tethered' jailbreak issue. You, yourself, admit that it only started after upgrading to a tethered JB.
My advice to you is to use untethered JBs whenever possible, because naturally a tethered JB depends on redsn0w to launch. (and could cause a problem if the battery is completely drained!
OS: Ubuntu 11.04
iProducts: Original iPad (64G /3G) redsn0w rc15
ehm,sorry to bump the thread guys,but I saw that you didn't help the first guy and I have the exact same problem(no signs of ipad to pc link)
more on it here:
www[dot]ifans[dot]com/forums/showthread.php?t=345022
(my first post,so no-links policy)
thanks in advance,
Alex
So, if you are on a TETHERED jailbreak and you have let the battery drain, the ONLY thing you can do is charge the iPad from the mains power adapter for a reasonable period of time (at least an hour), THEN perform the tethered boot procedure using whatever tool you normally have to use (I'm assuming an old version of redsn0w?)
iPad Enthusiast!
f4780y
I was going to suggest a full battery drain, but of what I understood from his post on the other forums, his problem is that he can't charge it from the mains.
Or did I get this completely wrong? :S
OS: Ubuntu 11.04
If you can't charge your iPad from the mains and your iPad battery is dead, you don't have many options left... If your PC equipment isn't up to spec to charge the iPad, there is no other magic solution I'm afraid.
Hi
I'm a noob at this so can you guys help me? how do you guys get pictures for your profile and how do you become a iPad fan or something else other than an iPad noob? Please respond
Thx so much
If his problem is really the PC just won't recognise the iPad then you have to troubleshoot the driver installation for your OS. It was undoubtedly interrupted and therefore is not correctly configured any more.
You need to get the current drivers removed and let them reinstall properly, but if your iPad does not have sufficient charge to allow this to complete, again you are out of luck. That's why you MUST get it charged from a wall outlet. If it won't charge from the official charger it indicates a hardware issue, which is probably why it won't connect to the PC...
Don't know what else to suggest. He says he has tried everything.
AdAbro
Hi
Thx so much
OK.
1. Don't hijack other peoples threads! Threads should always stay on topic. Hijacking is not on and breaks our rules - you should read them!
2. Update your avatar using the full website from your PC. You cannot do it from the iPad App. Select "User CP" at the top of the page and in that section you can change all your details including Avatar.
3. You are a n00b at the moment, and your ranking will change the more you contribute to the site. You can't change it yourself, but by your own admission, it seems to fit at the moment
Hope that helps.
I'm so sry!!
but thx for your help!
- You may not post replies
- You may not edit your posts
Forum Rules
By SallySparrow in forum iPad General Discussions
Last Post: 04-26-2013, 07:00 AM
By Kim in forum iPad Help
Last Post: 10-29-2010, 05:23 PM
Last Post: 09-29-2010, 11:09 AM
By MikesTooLz in forum iPad Hacking
Last Post: 08-09-2010, 09:35 AM
By Takenover83 in forum iPad Apps
Last Post: 05-11-2010, 05:46 AM
how to turn on a jailbroken ipad
how to turn on jailbroken on ipad
ipad battery dies during recovery mode
ipad can not start can not charge battery died
ipad empty battery cycling with apple logo
ipad is completely dead, tried all procedures, nothing works
ipad stuck at charging screen
ipad wont turn on after battery drain
iphoen tstuck at boot screen after battery flat
jailbreaked iphone wont start after battery drained
jailbroken ipad dead
jailbroken ipad doesnt charge
