Ipad restore problem,help needed badly
This is a discussion on Ipad restore problem,help needed badly within the iPad Hacking forums, part of the Apple iPad Discussions category; Since I am from India ,were Ipad is not officially available ,I had to buy it from someone from US at a premium price.I bought ...
Results 1 to 8 of 8
    iPad Enthusiast!
    28264
    kerala,India
    85
    Since I am from India ,were Ipad is not officially available ,I had to buy it from someone from US at a premium price.I bought Ipad 64gb 3g version with 3.2.2 FW. Things got sick,when I tried jb with limera1n.JB went fine,but after installing cydia,it crashed ,now am stuck with apple logo.I can get it into dfu mode,but on trying restore,am getting error like "not eligible for requested build" in mac or error 3014 and alike,when trying restore in windows.Anyway I havent yet crossed software verification step.....pls helpl me out to restore my ipad,no way I can go to service center as apple do not provide service for ipad in India.......
    14571
    596 times
    Sep 2010
    Troon, Scotland
    7,049
    Hi You won't be able to restore the iPad to 3.2.2 unless the guy you bought it from saved your SHSH files for that version. I would almost guarantee he didnt because you had to jailbreak it.
    You can check by downloading tinyumbrella on your PC, although I am not sure if TU will be able to see your iPad if it is stuck in recovery mode. You can give it a go and see.
    If they are saved, they will be on the Cydia server.
    Even if you cant use TU, you can point iTunes towards Cydia and see if you can then install 3.2.2. To do this, you need to change the hosts file on your PC and insert the line:
    74.208.10.249 gs.apple.com
    This will make iTunes ask Cydia for your blobs instead of Apple
    If this does not work, then you do not have SHSH's for 3.2.2 saved and you MUST restore 4.2.1 (the latest firmware). There is no other option as this is the only firmware you are entitled to from Apple. Put the iPad in DFU mode, remove the line in your hosts file if you inserted it earlier, and press the restore button on iTunes and let it download the latest 4.2.1.
    If you get stuck on any of these topics, search the forum as there is lots of information.
    Hope that helps.
    iPad Enthusiast!
    28264
    kerala,India
    85
    thank you....at least I got to know whats my problem is....and got some hope to see my ipad inn acion,was so desperate,of course my shsh files are not with cydia....but I dont mind updating ,
    And Itunes is directing me every time to 3.2.2 not 4.21?why? also my host file already have that line?is it because I already tried tinyumbrella? thanks in advance.....
    14571
    596 times
    Sep 2010
    Troon, Scotland
    7,049
    Quote Originally Posted by mathen View Post
    Yes, so to solve the problem, remove the line from your hosts file. iTunes should offer you only the latest firmware. You can always download it from apple.com and then use shift-restore (or option-restore) and point iTunes to the file you downloaded if there continues to be an issue... That way you know what exact firmware you are installing...
    Good Luck!
    18148
    Oct 2010
    PNG
    12
    when u use tiny umbrella, remember to click on the ipad icon on the left panel under device, then select exit recovery. i faced the exact problem like you last time. problem is due to i sync when cydia is still downloading installous or limerain is installing cydia. shd be easy to solve your problem.
    iPad Enthusiast!
    28264
    kerala,India
    85
    Quote Originally Posted by uniquexme View Post
    so that I tried installing with 4.2.1 ,now getting an error 11 but am still optimistic,there should be some way around
    iPad Enthusiast!
    28264
    kerala,India
    85
    Thanks to f4780y, i tried restore on my mac with fw 4.2.1,it worked !!!1thanks to all how tried to help me out
    14571
    596 times
    Sep 2010
    Troon, Scotland
    7,049
    You are welcome. Glad it was sorted.
  1. need imexchange advice BADLY...thanks..
    By corb in forum iPad Apps
    Last Post: 08-21-2012, 12:43 PM
  2. Restore from back up problem
    By greedenko in forum iPad Help
    Last Post: 12-18-2010, 03:37 AM
  3. Badly In Need of ipad DVD and video tools!!
    By kiwifruit1234 in forum iPad General Discussions
    Last Post: 09-30-2010, 04:06 AM
  4. Need help with restore problem
    By Billee in forum iPad Help
    Last Post: 08-14-2010, 05:16 PM
  5. restore ipad from shsh or regular restore+jailbreak
    By bdaddy in forum iPad Hacking
    Last Post: 07-12-2010, 04:55 PM
error 3014 ipad
ipad bad restore
ipad not eligible for restore
ipad restore error 11
ipad restore help
ipad restore problem
ipad restore problems
ipad will not restore error 3014
iphone 4 not eligible restore or error 3014
iphone 4 restore not eligible or error 3014
is restoring an ipad bad
restore needed on ipad
