iFile Problem
This is a discussion on iFile Problem within the iPad Hacking forums, part of the Apple iPad Discussions category; Here's my problem..when I'm trying to connect my external hard drive via the CCK, it is not showing up in iFile. If I use the ...
Results 1 to 3 of 3
Thread: iFile Problem
    13582
    4 times
    Aug 2010
    Indiana
    342
    iFile Problem
    Here's my problem..when I'm trying to connect my external hard drive via the CCK, it is not showing up in iFile. If I use the SD card reader and pop an SD card in it shows up immediately as a flash drive. Using terminal I typed ls dev and it recognized that the drive is connected and then I manually mounted it to a folder and iFile seen it just fine. Here's what I dont get...I had to do a restore tonight and before I restored, iFile would see the drive immediately after I plugged it in like the SD card. Already tried removing and reinstalling iFile to no avail.
    There is only one Return, and it's not Of The King, it is Of The Jedi.
    27427
    You may have to do a full restore and start over with everything. I don't understand why did you have to Use terminal to type ls dev for the drive to show? Once I installed ifile through cydia first then put the CCK/SD in the pad, clicked on ifile went to var/mt/mount1 and my SD card files were there.
    34215
    Feb 2011
    Sorry, but I have to do this.... "Rise old thread. Rise!"
    At any rate, did you ever find a solution to this? I to remember connecting an external HD to my ipad thru the cck and iFile will notice it Immediately.
    Since then i've done a restore and just tried to connect an external HD with no luck.
  1. Ifile assistance, Plz
    By Demandarin in forum iPad Help
    Last Post: 03-31-2011, 12:57 AM
  2. a question about ifile
    By addiosamigo in forum iPad Hacking
    Last Post: 10-28-2010, 02:54 AM
  3. iFile image uploading and viewing
    By kizer in forum iPad Hacking
    Last Post: 10-22-2010, 09:21 PM
  4. Ifile : where can I find my video files ?
    By Chad in forum iPad Hacking
    Last Post: 10-03-2010, 09:54 PM
  5. iFile
    By Wakawaka in forum iPad Hacking
    Last Post: 09-24-2010, 02:15 AM
files not showing up in ifile
ifile
ifile does not recognize hard drive
ifile external viewers
ifile external viewers not working
ifile not connet
ifile not recognising usb drive
ifile not working
ifile problem
ifiles trouble ipad
ipad no files show up on ifile
iphone sd card reader ifile
