Safari Problem after removing Jailbreak.
This is a discussion on Safari Problem after removing Jailbreak. within the iPad Hacking forums, part of the Apple iPad Discussions category; Earlier this evening I Jail broke my iPad 4.2.1 version and then removed it after the difficulties I had understanding it. After removing it I ...
Results 1 to 2 of 2
    26412
    Dec 2010
    Exclamation Safari Problem after removing Jailbreak.
    Earlier this evening I Jail broke my iPad 4.2.1 version and then removed it after the difficulties I had understanding it. After removing it I restarted the iPad and found that the Safari web browser would not start up. I never had this problem before and during the Jail break but since removing it Safari wont work.
    I would be very great full to anyone who could offer help or advice.
    14571
    596 times
    Sep 2010
    Troon, Scotland
    7,049
    I am not sure how you removed the jailbreak. Can you explain? It sounds as though you haven't done it properly since Safari (which is moved as part of the jailbreak process) will only work if the iPad is booted in a pwnd state (using redsn0w). To boot the iPad in a jailbroken state you must run redsn0w and select the check box which says "just boot tethered for now". You must do this EVERY time you reboot your iPad. This is why it is known as a tethered jailbreak.
    To properly remove the jailbreak you MUST do a full restore to stock 4.2.1 through iTunes.
    Then you should find that everything will work as normal.
    Hope this helps.
  1. Little problem with safari and pdf
    By gymvideo in forum iPad OS
    Last Post: 09-02-2011, 04:11 PM
  2. Removing Jailbreak
    By kevinthemovie in forum iPad Hacking
    Last Post: 04-26-2011, 11:30 AM
  3. safari problem
    By craigstockport in forum New Member Introductions - Site Assistance
    Last Post: 04-07-2011, 05:02 AM
  4. Strange safari problem
    By Tobiasrx in forum iPad Help
    Last Post: 10-19-2010, 07:13 AM
  5. Safari Browser Bar Problem
    By write-stuff in forum iPad General Discussions
    Last Post: 05-10-2010, 12:42 PM
how to make safari work on ipad after os6
how to remove a tethered jailbreak that doesnt work
how to uninstall jailbreak
iphone safari won't open after jailbreak
safari browser wont work when i remove jailbreak
safari doesn't work after jailbreak
safari not working after jailbreak
safari not working on ipad after jailbreak
safari won't open on iphone after jailbreak
safari won't work after jailbreak
tethered jailbreak delete
Tags for this Thread
