Low memory issue :(
This is a discussion on Low memory issue :( within the iPad Hacking forums, part of the Apple iPad Discussions category; Hey, I don' t know if this issue convenient here but my ipad has really low memory since I jailbroke it. Especially "wired memory" has ...
Results 1 to 2 of 2
Like Tree2Likes
  • 2 Post By Mickey330
Thread: Low memory issue :(
    199077
    May 2012
    İstanbul
    50
    Exclamation Low memory issue :(
    Hey,
    Especially "wired memory" has the most usage (I still can' t find what it means or does).
    Thanks for help...
    iPad 3 16GB Wifi + 4G / 7.0.4 Jailbroken
    13576
    1454 times
    Aug 2010
    Western NY state (USA)
    11,066
    Quote Originally Posted by srkhn View Post
    Hey,
    Thanks for help...
    You're going to have more use of your iPad's RAM because of the tweaks you've installed. However, if the tweaks are well-written, they won't interfere with the normal RAM management Apple built into the iPad. Apps will still be in suspension until re-opened by you or asked by the iOS to close because another app needs the RAM. This is all automatic, so, unless you have a continuing crash, there is really nothing to be concerned with about how much RAM is available at any given time.
    Apple has designed a pretty robust RAM management system the operates on the theory [paraphrased] that unused RAM is useless RAM.
    Oh, and "wired memory" is RAM "used by the OS which is pretty much untouchable. Another application can't 'borrow' wired memory." I should imagine that putting tweaks on that need to respond immediately or change the function of your iPad would require a bit more "wired memory" than stock so they are available.
    Hope that helps.
    willerz2 and srkhn like this.
  1. Memory issue?
    By toottoot in forum iPad Mini Forum
    Last Post: 08-30-2013, 05:58 PM
  2. Confusing memory issue with ipad1
    By 33elmcroft in forum New Member Introductions - Site Assistance
    Last Post: 03-04-2013, 05:48 PM
  3. Ipad 2 Memory issue?
    By noteven in forum iPad 2 Forum
    Last Post: 07-26-2012, 12:45 AM
  4. Memory issue..
    By Zujalica in forum iPad Hacking
    Last Post: 12-08-2011, 09:10 AM
  5. Memory issue
    By Dcawd in forum iPad General Discussions
    Last Post: 10-11-2010, 09:40 AM
