please help me to fix my ipad2
This is a discussion on please help me to fix my ipad2 within the iPad Hacking forums, part of the Apple iPad Discussions category; hey, i have an ipad2 on jailbreak, and i try upgrade version of my ios from 5.1.1 to 6.1.3 but my ipad broke and go ...
Results 1 to 8 of 8
    285100
    Mar 2013
    indonesia
    5
    hey, i have an ipad2 on jailbreak, and i try upgrade version of my ios from 5.1.1 to 6.1.3 but my ipad broke and go to recovery mode, i try to restore with itune but it couldn't
    im so panic and i used reds0w to restored it but
    but it says RE-restore failed
    pleeeaaaseee help meee!!!! and give me solution, im so panic now
    285100
    Mar 2013
    indonesia
    5
    it say like that
    48665
    947 times
    Brisbane, Australia
    23,484
    Hi and welcome to the Forum!
    I've moved your thread to our Hacking Section where you will receive a better response.
    Good luck with your issue!
    Please read the Forum Rules
    iPad Air 128gb Wifi/Cellular - iPad 2 64gb Wifi/Cellular - iPad Mini 32gb Wifi/Cellular - iPhone 5 - Apple TV - MacBook Pro 15" - Time Capsule - Airport Express
    285100
    Mar 2013
    indonesia
    5
    Smile thank's
    thank's and please give me a solution
    285100
    Mar 2013
    indonesia
    5
    i cant restore my ipad2
    please help me to fix my ipad2-38211d1363920845-please-help-me-fix-my-ipad2-screenshot-10-.png
    help meee pleaseee
    13576
    1447 times
    Aug 2010
    Western NY state (USA)
    11,054
    Okay, it appears you are trying to do two different things. So, to break it down:
    (1) If you are trying to upgrade the iPad to iOS 6.1.3, then get the software from this link: Official Apple IOS Firmware Download Links for iPad
    This way, you don't have to worry that iTunes can't get to the server as you'll have the firmware you need. You can do the shift/restore process to restore the iPad to iOS 6.1.3, which is the newest (and only) iOS you can upgrade to.
    Do note, however, that iOS 6.1.3 is not jail breakable at this time. If you upgrade, you will lose your jail break.
    Or,
    (2) If you are trying to re-restore iOS 5.1.1 onto that iPad - do you have SHSH blobs for that iOS? Because the re-restore will not work if you don't have the blobs.
    P.S. I moved your other post you started today on this same topic (over in another thread) to this thread. Making more than one post not only fragments the conversation and makes it hard to follow - it's against the forum rules. Please keep any follow-ups, discussion or updates on this topic to this thread; do not start another. Thanks for your understanding.
    285100
    Mar 2013
    indonesia
    5
    i tried it many times, but couldn't, i was downloaded the 6.1.3 ipsw and i use shift+restore but didn't work
    do you have any solution??? pleaseee
    14571
    632 times
    Sep 2010
    Troon, Scotland
    7,104
    Well you have TinyUmbrella running (twice by the looks of it). You won't be able to restore your device properly whilst it is running. Go to the Advanced Tab in TU and make sure you have "Request SHSH from Cydia" UNTICKED. That is very important. Then you must QUIT TinyUmbrella.
    Try the restore in iTunes again after that and you should be OK.
    iPhone5 32GB 6.1.2 (evasi0n) | iPhone4S 64GB 5.1.1 (absinthe) | iPhone4 32GB 7.0b2 (stock) | iPhone3G 16GB 3.1.3 (jbme) | iPod Classic 6G 160GB (stock) | AppleTV 2G 5.0.2 (seas0npass)
  1. Replies: 9
    Last Post: 08-13-2012, 11:03 PM
  2. IPad2 Mifi usage with non 3G ipad2
    By Michael Lane in forum New Member Introductions - Site Assistance
    Last Post: 07-11-2012, 03:36 AM
  3. Replies: 12
    Last Post: 12-29-2011, 11:04 AM
fix my ipad 2
help me restore my ipad
Tags for this Thread
