Jailbroken ipad 2 stuck in recovery mode, help please :/
This is a discussion on Jailbroken ipad 2 stuck in recovery mode, help please :/ within the iPad Hacking forums, part of the Apple iPad Discussions category; So today.. i made the stupid decision of installing a update from itunes to my jailbroken ipad 2 & ended up being left with a ...
Results 1 to 10 of 14
Like Tree2Likes
Thread: Jailbroken ipad 2 stuck in recovery mode, help please :/
    284481
    Mar 2013
    So today.. i made the stupid decision of installing a update from itunes to my jailbroken ipad 2 & ended up being left with a ipad in recovery mode.
    I've tried using the program Tiny Umbrella to exit it but no luck.
    I've also tried the manual restore with 6.1 update ipsw file i downloaded but i still get a error.
    Been trying for the past 6 hours but i'm getting nowhere ._. I'm hoping someone could help me out, it'll be extremely appreciated.
    Thanks in advance.
    13576
    743 times
    Aug 2010
    Western NY state (USA)
    9,263
    Try doing the manual restore again, but this time, use the IPSW for iOS 6.1.2. That is the most current iOS (as in - trying to install iOS 6.1 won't work being its no longer authorized by Apple).
    So, put your iPad back into DFU mode and then use the shift/restore process so you can select the most current iOS. It should work with no further issue.
    If you have continuing problems, holler back and we'll take another shot at it. Good luck.
    TheAmplifier likes this.
    284481
    Mar 2013
    Thanks, i'll give this a go
    284481
    Mar 2013
    Quote Originally Posted by Mickey330 View Post
    284481
    Mar 2013
    Thanks a lot for your help! It worked
    This site is awesome
    13576
    743 times
    Aug 2010
    9,263
    Yay! Glad to hear that things got sorted for you. And, thanks for coming back and telling us your problem got resolved. Always nice to hear back - especially the success stories.
    285526
    Mar 2013
    Hoping you can help
    My wife has this same issue and mistakenly an the update to 6.1.3 without having run a backup first. Can you share a bit more on how to enter back to the DFU process and the correct way to do this process? I want to be sure to not mess it up as there is a lot of application data that would be devastating to her if lost. thanks so much for your help!
    Regards,
    Chris
    13576
    743 times
    Aug 2010
    9,263
    Quote Originally Posted by bentley311 View Post
    Regards,
    Chris
    I guess I don't understand your issue. Do you have an iPad stuck in recovery mode or is your iPad now running iOS 6.1.3, correct? If it's on iOS 6.1.3, then that's where it has to stay. There is no other iOS you can put on it.
    For "peace of mind" - check the apps that have data. They should be fine and have all the data that was there before the upgrade/update was done. Oh, and you can connect the iPad to iTunes and run a backup now (as it's always a good idea to run backups on a regular basis anyway).
    P.S. And, just for educational reasons, here's the tutorial my fellow moderator, f4780y, made on DFU Mode: DFU Mode for Dummies. It's good reading for the future or in case you need to re-install iOS 6.1.3 for some reason...
    285526
    Mar 2013
    It is stuck in recovery mode. I am thinking that based on what I have read, there i no way to restore it any way that will preserve the data from the apps? I knew it was a long shot, but I wanted to check into it. I know when a Windows machine OS goes belly up, you can still access files on the hard disk. Was hoping there was a similar process on this device in which data could still be retrieved before wiping it out.
    Thanks,
    Chris
    14571
    595 times
    Sep 2010
    Troon, Scotland
    7,048
    If the update didnt go through, then you should be able to exit recovery mode by using a tool such as TinyUmbrella (download from there - The Firmware Umbrella - TinyUmbrella) or redsn0w.
    When you launch TU, it has a button on the top right hand panel saying "Exit Recovery". If the previous IOS is still intact, the iPad should boot as normal once you do this.
    Good luck.
  1. My ipad stuck on recovery mode
    By maria liza bueta in forum iPad General Discussions
    Last Post: 01-31-2013, 10:51 AM
  2. IPad 3 Stuck in Recovery Mode
    By ExCalif in forum iPad 3 Forum
    Last Post: 05-27-2012, 12:26 AM
  3. Help! Ipad Stuck on Recovery Mode
    By ecthelionv2 in forum iPad Hacking
    Last Post: 05-23-2012, 09:55 PM
  4. My iPad 2 is stuck in recovery mode!
    By Shushant in forum iPad OS
    Last Post: 02-04-2012, 02:57 AM
  5. iPad is stuck in DFU mode or Recovery..
    By HayleyHurrr in forum iPad 1 Forum
    Last Post: 12-12-2011, 08:51 AM
end jailbroken ipad 2 recovery mode
exit recovery mode in ipad
how to restore a jailbroken ipad stuck in recovery mode
ipad 2 exit recovery mode
ipad 3 exit recovery mode
ipad locked in recovery mode
jailbroken ipad 2 stuck in recovery mode
my ipad2 is in recovery mode jailbroken
recovery mode on jailbroken ipad2
