Mobilesubstrate is not functioning problem
This is a discussion on Mobilesubstrate is not functioning problem within the iPad Hacking forums, part of the Apple iPad Discussions category; After I used evasion to jailbreak ios6.1.2 , I got a problem about Mobilesubtrate is not functioning , some tweaks in Cydia require to respring ...
Results 1 to 6 of 6
    52878
    May 2011
    28
    After I used evasion to jailbreak ios6.1.2 , I got a problem about Mobilesubtrate is not functioning , some tweaks in Cydia require to respring after installing, I pressed respring then i got 70% chances to get this message after a very long reboot..... It's very annoying, plz help
    Attached Thumbnails Attached Thumbnails Mobilesubstrate is not functioning problem-image-1013683889.jpg
    13576
    1447 times
    Aug 2010
    Western NY state (USA)
    11,055
    More than likely, you've got some tweak installed that is incompatible with the iPad or your iOS (or both). IMO, that's why Mobile Substrate keeps throwing you into Safe Mode.
    So, I think you've got a Mobile Substrate-using tweak that is not working properly. If you can remember, try to uninstall any tweaks you loaded just before this behavior began. Or, if you have SBSettings installed, turn off all the Mobile Substrate items. Then, turn them on, one by one (respringing in between) to see if you can find which one is the culprit. If you locate one that is causing the issue, then uninstall it from Cydia (but make sure it's turned ON in SBSettings - else it'll cause additional issues).
    If you can't remember what tweaks you've installed or the checking Mobile Substrate items doesn't help (or you don't have SBSettings), may I ask that you list all the tweaks you currently have installed. Maybe we can help you ID the "culprit(s)"...
    52878
    May 2011
    28
    Quote Originally Posted by Mickey330 View Post
    Thx, but the problem is its not in safemode , because not all tweaks are disable like safemode, all tweaks are still enable but some of them are not functioning , when I enter the Activator Setting then it popups the message( image ) , I thought the latest version of evasion would solve the problem but its not
    52878
    May 2011
    28
    I can return to normal springboard when I press restart
    iPad Addict
    167823
    187 times
    Feb 2012
    New York
    1,136
    Check the compatibility of your Cydia tweaks and apps and find the problem there. Here's a fairly large list that you can reference to
    https://docs.google.com/spreadsheet/...owsperpage=600
    iPhone 4S White 16 GB iOS 7.1 ||iPad Mini 16GB (WiFi) iOS 7.0.4 Evasi0n7||AppleTV2 iOS 5.2 Seas0nPass
    Please read and abide by the forum rules
    iPhone Forums Moderator
    52878
    May 2011
    28
    Quote Originally Posted by willerz2 View Post
    Thx a lot
  1. Camera not functioning
    By Zuno86 in forum iPad Help
    Last Post: 08-23-2013, 07:39 PM
  2. Replies: 3
    Last Post: 03-17-2012, 07:44 AM
  3. Replies: 0
    Last Post: 01-07-2012, 11:33 AM
  4. Zagat to go not functioning
    By SPOLSKY in forum iPad Apps
    Last Post: 04-13-2010, 07:19 PM
mobile substrate is not functioning
mobile substrate is not functioning ios 6
mobile substrate is not working
mobile substrate not functioning
mobile substrate not working
mobilesubstrate not functioning
mobilesubstrate not functioning ios 6
mobilesubstrate not working
