How Do These Sound Boxes Make Sound?
This is a discussion on How Do These Sound Boxes Make Sound? within the iPad General Discussions forums, part of the Apple iPad Discussions category; I'm an Ipader and looking for a speaker for my phone. I found a type of USB-charged ones( http://www.tinydeal.com/apple+Mini+USB+Powered+Vibrating+Audio+Resonance+S peaker234 and http://www.tinydeal.com/apple+Mini+USB+Powered+Vibrating+Audio+Resonance+S peaker127 ) online ...
Results 1 to 6 of 6
    Banned
    14471
    Sep 2010
    USA
    I'm an Ipader and looking for a speaker for my phone. I found a type of USB-charged ones(http://www.tinydeal.com/apple+Mini+USB+Powered+Vibrating+Audio+Resonance+S peaker234 and http://www.tinydeal.com/apple+Mini+USB+Powered+Vibrating+Audio+Resonance+S peaker127) online yesterday. They are shaped like apples and their brand name starts with an "i" -- obviously to cater for apple. But i've found no hole on the small sound boxes, so I wonder where sound is sent out. Anyone tell me about the stuffs?
    10547
    Jul 2010
    London
    19
    I've used a similar one. On the bottom of it, there is an elastic button to control the sound volume and subwoofer strength. When a heavier pressure is imposed on the button, the subwoofer become stronger. And a mild subwoofer is made when the box is put upright on a desk. In fact, the speaker itself produced very weak sound, and it generates stereo by vibrating the surface of a desk, or the panel of your car. As the source of voice is usually long or round, you may find solid voice come from every direction.
    9558
    Jul 2010
    New York
    16
    i saw somewhere on the net once some suckers that go onto a window, you then connect them with a jack plug to a music source and the window becomes the speaker
    10547
    Jul 2010
    London
    19
    Quote Originally Posted by Applefreak12 View Post
    I'm so interested in such stuffs and search about them on the Web.
    I think the apple-like speaker somewhat used the planar speaker technology. A planar speaker can be in the shape of a frame and also other shapes. And the following is an illustration on how such a speaker works.
    The vibration plate is actually a flat panel made from some selected materials. When a flat panel speaker is electrified, its magnetic-material-made exciter begins working to trigger off some complex wave motions on the panel, through which, sound is sent out.
    According to some reports, a flat panel speaker performs better in terms of fidelity than a conventional one, which, in the shape of a cone, often produces twisted voices -- a conventional speaker compresses voices before sending it out. Besides, a wide angle or a long distance between a flat panel speaker and its user doesn’t impair his enjoyment so much, because the stuff emits HiFi sound waves to more directions (voices are spread more evenly).
    If the speaker you linked adopted the flat panel technology, the button on the bottom should have served as a an exciter and the desk played the role of a vibration plate. Am I right?
    There is a story about the derivation of flat panel speakers, by the way. At then end of the 1980s, researchers of the UK Ministry of Defence tried some flat composite materials to conceal military helicopter engines, in an effort to lower noises. But the noises were not impaired. Moreover, these materials make sound by vibrating, just like a loudspeaker. Then the researchers began the R&D of flat panel speakers. And established in 1996, NXT has long been devoted to the field.
    iPad Ninja
    772
    5 times
    Feb 2010
    Near Montréal Québec
    1,932
    The traditional speaker is made of an electromagnet connected to a flexible membrane, the paper around it. This magnet motor goes up and down transmitting its movement to the surrounding paper or plastic that amplifies that movement. The more the vibration, the more amplitude it gets, the louder the volume of sound.
    This device appears to have a coil end that would make the surface it touches resonate. The thinner the surface the louder it will vibrate. Put it on a drum head surface and it will do its best.
    The apparent genius of this one is that it's standing on its coil making the whole device move up and down instead of the other way around, giving more mass for such a light device to transmit vibration.
    Not white, not black just passionate shades of grey...
    Yuno Wataï Minh
    Banned
    14471
    Sep 2010
    USA
    But what kind of surface or panel best realize its function?
  1. No sound in headphones
    By ncbrew in forum iPad General Discussions
    Last Post: 03-18-2012, 11:19 PM
  2. Ipad sound but no video when connected to TV
    By Ghostontheline in forum iPad Help
    Last Post: 08-28-2010, 12:25 AM
  3. Avidemux .mp4 method - No sound!
    By Arthur Hucksake in forum iPad General Discussions
    Last Post: 08-04-2010, 07:32 AM
  4. sound recordings where to find
    By littlebuddha in forum iPad Help
    Last Post: 06-15-2010, 02:05 AM
exciter speakers
flat panel speaker
flat panel speakers
flat speaker technology
flat-panel speaker
how can i make my ipad louder
how to make a little sound box
how to make sound box
large flat speaker sound box
nxt sound source flat panel speakers
vibration exciter
vibration speaker module
