iPad 4 not connecting to WiFi network
This is a discussion on iPad 4 not connecting to WiFi network within the iPad General Discussions forums, part of the Apple iPad Discussions category; I have two iPads in front of me - mine (iPad 3, WiFi only) and a friend's (iPad 4, WiFi and 3G). The iPad 4 ...
Results 1 to 5 of 5
    181396
    Mar 2012
    Arizona, USA
    38
    I have two iPads in front of me - mine (iPad 3, WiFi only) and a friend's (iPad 4, WiFi and 3G). The iPad 4 has no data plan yet. Both iPads have iOS 6.0.1.
    My iPad is and stays connected to my WiFi network (as well as my iMac and two MacBooks) but the iPad 4 looses the connection all the time and very often does not even join the network (message: "Unable to join the network xxx"). This is basically true for both of my networks (2.4 GHz and 5 GHz). It works somehow better for the 2.4 GHz network and is very bad with the 5 GHz network). Restarting the iPad does not help.
    What I also notice is that the iPad 4 is seeing less available networks than the iPad 3 (but it always sees both of my networks).
    Any idea what might be wrong here and how it can be fixed? I know there is already an iOS 6.0.2 but as far as I know it is only for the iPad mini and the iPhone 5 and anyway my iPads here say that the software is up to date with iOS 6.0.1 and an update is not possible.
    iPad 3 WiFi (iOS 6) i5 iMac (OS X 10.8)
    49720
    412 times
    SC
    6,330
    Reset the network settings...,
    mini iPad w/ RD - 128 LTE - Space Grey | iPad mini - 64 GB - LTE - Black | iPad (3nd Gen) - 64GB - LTE - Black | iPhone 4S - 64GB - White | Nexus 10 | Nexus 7 2013 | Kindle Fire
    * * * Forum Rules * * *
    181396
    Mar 2012
    Arizona, USA
    38
    Quote Originally Posted by AQ_OC View Post
    Doesn't make any difference. Now the iPad 4 does not connect at all anymore to the 5 GHz network, only to the 2.4 GHz network. The iPad 3 can connect to both networks and the iPad 3 is also still seeing more available networks (although by far not as many as my iMac sees - in the moment I see 3 networks on my iPad 3 and 12 on my iMac).
    181396
    Mar 2012
    Arizona, USA
    38
    I deleted the networks on the router and recreated them again and now both iPads do connect to both networks. No idea why this was necessary.
    1523 times
    Walla Walla, WA
    15,431
    You could have probably just restarted the router(s).
    Routers can take a dislike (for lack of a better technical term) to certain devices, remembered by their unique MAC address. This is fairly common for iOS devices for some reason. Restarting the router clears the logs and buffers, giving the device a clean slate.
    The other possibility is that when you recreated the networks you also reconfigured them to support the IP6 internet standard. You don't have to do this for the local network, but it needs to be supported on the WAN side.
    However, all the newest iOS devices need this in order to authenticate properly, and since your iPad 4th gen was already working it seems unlikely to have been the problem.
  1. Replies: 50
    Last Post: 10-12-2012, 10:42 PM
  2. Connecting IPad to WIFI
    By SNOWDROP252 in forum iPad 2 Forum
    Last Post: 04-30-2012, 12:34 AM
  3. Connecting from iPad to network devices
    By tate16t in forum iPad 3 Forum
    Last Post: 04-15-2012, 05:56 PM
  4. New iPad not connecting to wifi :(
    By ladynikon in forum iPad 3 Forum
    Last Post: 03-16-2012, 10:25 AM
  5. Problem connecting to wireless home network
    By colinicky in forum iPad 1 Forum
    Last Post: 01-02-2012, 09:54 AM
ipad 4 does not connect to wifi
ipad 4 not connecting to wifi
ipad 4 problem connecting to wifi
ipad 4 will not connect to wifi
ipad not connecting to wifi
ipad not connecting to wifi at home
ipad not connecting to wifi network
my ipad 4 is wifi only but will not find networks
