Using GarageBand to create Ringtones/Alerts
This is a discussion on Using GarageBand to create Ringtones/Alerts within the iPad General Discussions forums, part of the Apple iPad Discussions category; Here is an almost easy way to make your own ringtones/alerts sound using GarageBand on iOS: 1 - Start GarageBand on your device 2 - ...
Results 1 to 1 of 1
Like Tree2Likes
  • 2 Post By DrHouse
Thread: Using GarageBand to create Ringtones/Alerts
    29813
    20 times
    Quebec
    642
    2 - Create a new song
    3 - Select any instrument, it does not really matter for now
    4 - Click on the icon that will show all your tracks instead of the instrument view. This is the second icon from the top left on an iPhone...
    5 - Once in track mode, click on the loop icon (It looks like a small loop...)
    6 - You will now see some loop samples. At the top, you can select audio files and also Music...
    7 - Select the Music tab. Find your favorite song and "Press and Hold" it to import it as a new track
    8 - at this point, you should now be back to the track view. Your song has replaced the previous track or it was added as a new track. Delete unwanted track by "pressing and holding" the track until a menu shows up....
    9 - Edit your track to your liking...
    10- Once done, return to the main screen of GarageBand where it is showing all your created songs.
    11- Press and hold your new song to activate the "Share" icon. At the bottom, you can export your song in your Ringtones
    12- Simply follow the instruction and set your new Ringtone as an alert, or a custom ringtone...
    It is also possible to record any other sound by using the "Microphone" instrument. Start any music app that can play in the background and going back in GarageBand, you can record whatever is playing with a good enough quality sound. Just don't speak while doing this
    Have fun!
    Attached Thumbnails Attached Thumbnails Using GarageBand to create Ringtones/Alerts-image-1329405143.jpg   Using GarageBand to create Ringtones/Alerts-image-1424641346.jpg   Using GarageBand to create Ringtones/Alerts-image-4233726867.jpg   Using GarageBand to create Ringtones/Alerts-image-3557707288.jpg   Using GarageBand to create Ringtones/Alerts-image-2963176095.jpg
    Using GarageBand to create Ringtones/Alerts-image-3803040359.jpg   Using GarageBand to create Ringtones/Alerts-image-1858023787.jpg   Using GarageBand to create Ringtones/Alerts-image-1971545774.jpg   Using GarageBand to create Ringtones/Alerts-image-733423402.jpg   Using GarageBand to create Ringtones/Alerts-image-757669756.jpg
    Using GarageBand to create Ringtones/Alerts-image-3502673101.jpg   Using GarageBand to create Ringtones/Alerts-image-3370496812.jpg
    Gabriel1 and Steve220 like this.
    iPhone 4S 16Gigs 5.01
    iPad 1 16 Gigs Wifi 5.01
    Canada / Rogers
  1. Garageband IOS6 and Ringtones
    By kestrel1 in forum iPad General Discussions
    Last Post: 09-20-2012, 05:06 AM
  2. Replies: 0
    Last Post: 03-21-2012, 05:07 AM
  3. Ringtones
    By Mitch1950 in forum New Member Introductions - Site Assistance
    Last Post: 01-26-2012, 04:05 PM
  4. Ringtones Help
    By Munky in forum iPad Help
    Last Post: 12-16-2011, 07:31 AM
  5. Create Iphone Ringtones
    By suprablitz in forum Off-Topic
    Last Post: 07-18-2010, 02:16 AM
