Results 1 to 3 of 3
    202800
    May 2012
    93
    Question: Does my iPad Case Effect WiFi?
    Does an iPad case like my Zagg Folio (plastic) have any effect on wi-fi reception speeds? T.I.A.
    173557
    60 times
    Mar 2012
    537
    Is it possible? Technically yes, if it met some very interesting design constraints.
    Is it likely? No. Plastic at that thickness doesn't attenuate the signal.
    Facts are the first casualty of bad information.
    85546
    517 times
    Aug 2011
    Edmonton AB Canada
    9,720
    It shouldn't have much effect, if any. There will be some degradation of the signal, since any radio wave will lose power going through a solid medium, but it would be such a tiny amount that I doubt the effect could be measured.
    Lets face it, your wifi signal is already travelling through walls etc. Right now, mine is travelling through a double thickness wooden wall, an insulated steel exterior wall and a truck window. The router (a not very new Linksys unit) is around 100 yards from where I'm sitting, and I have a good signal.
  1. Question about stylus effect on iPad screen
    By youngun in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 04-18-2012, 07:33 AM
  2. Replies: 3
    Last Post: 03-28-2012, 01:50 AM
  3. Ipad wifi question.
    By Autobot in forum iPad Help
    Last Post: 09-15-2011, 09:14 PM
  4. ipad 2 wifi only question
    By irish1759 in forum iPad 2 Forum
    Last Post: 05-11-2011, 09:55 PM
  5. iPad case interfering with Wifi?
    By kpbrian in forum iPad General Discussions
    Last Post: 08-01-2010, 08:21 PM
can the ipad case affect wifi
can the ipad case affect wifi signal?
do cases affect ipad wifi?
do cases affect wifi
do cases effect wifi
do ipad cases affect wifi?
does cas affect wifi
does cases wifi
does my case affect my wifi?
does the ipad case affect wifi speed
ipad case interfere with wifi
ipad cover effect wifi
