Problems With Native Media Player
This is a discussion on Problems With Native Media Player within the iPad General Discussions forums, part of the Apple iPad Discussions category; Hi there A while back I was experiencing problems with transferring music and video from my pc to ipad. I discovered iFunbox and installed it. ...
Results 1 to 6 of 6
    249249
    Oct 2012
    South Africa
    Hi there
    A while back I was experiencing problems with transferring music and video from my pc to ipad. I discovered iFunbox and installed it. A google search led me to someone who had had a similar problem and I followed his suggestion of deleting two files in the iTunes Control section of the iPad. Ever since then when I transfer music and video to the ipad they play back highly distorted and choppy. if I play the files on a 3rd party app they play perfectly which means it is not an issue with the file itself. It is just just when using the native music player and the native video player that the playback is distorted. Last weekend I did a full system restore to factory settings but the issue has remained. What was curious was that when irebooted io6 was still there and didn't redownload from scratch which is what I would think would need to happen as I am sure I need to reinstall the iTunes files I deleted. I know i am at fault here and was stupid to delete files I should not have touched. Is there any way to do a reinstall of iTunes on its own on the ipad or update its system files? Would I be able to copy them across form someone else's ipad using iFunbox? Any assistance will be greatly appreciated.
    dvdcatalyst
    Guest
    I have no idea if this will work the same way with an upgraded iPad3, but this might help:
    How To: Put your iPad into Recovery Mode
    You might be able to copy the files over from another iPad, but it depends on how you deleted the files in the first place. You didn't mention how you deleted the files, but to delete core system files, you would need to be jailbreaked in order to be able to access/delete them.
    249249
    Oct 2012
    South Africa
    [QUOTE="You didn't mention how you deleted the files, but to delete core system files, you would need to be jailbreaked in order to be able to access/delete them.[/QUOTE]
    I deleted them using iFunbox which allows access to system files without being jailbreaked. It's an alternative to iTunes.
    dvdcatalyst
    Guest
    ah ok.
    well the suggestion for recovery remains, but maybe try copying the files you deleted from a different ipad.
    looking at the ifunbox page it seems like it does some decryption and filehandling so it might work.
    no idea if it would work or what it would do if it doesnt work though.
    249249
    Oct 2012
    South Africa
    Quote Originally Posted by dvdcatalyst
    ah ok.
    Thanks. Am trying with a friends iPad today via iFunbox. If that doesn't work I'll do the full recovery. It makes sense to me that recovery will work as iTunes and its system files are surely all part of iOS
    dvdcatalyst
    Guest
    Quote Originally Posted by Buggles View Post
    with some digging you might find a tool that might let you open the actual ipa file for the ios update you are running on your ipad and then extract the files you deleted from there, but that will get a bit more technical. its been a few years for me when i was that deep in modding my ipod touch, and i havent kept track as to what mods are possible since, but back then there were ways to do it, so some might still exist.
    but there is always recovery :
  1. Remove Native iPad 2 Music Player
    By Scyrax91 in forum iPad Help
    Last Post: 08-21-2012, 11:45 AM
  2. NAS/Media Player/App combination to stream media, controlled from iPad
    By thelongroad in forum iPad General Discussions
    Last Post: 01-06-2012, 08:35 PM
  3. media player
    By valetta11 in forum iPad Help
    Last Post: 11-05-2011, 10:10 AM
  4. VLC media player remote
    By Ipadfan2011 in forum iPad General Discussions
    Last Post: 03-29-2011, 10:44 AM
  5. Since the demise of VLC media player what's the best player for video
    By lanimae in forum iPad General Discussions
    Last Post: 03-25-2011, 10:45 PM
how to copy music from pc to ipad 1 using ifunbox
ifunbox recovery music doesn't work
ipod video music wont show in my ifunbox
is vlc media player available for ipad
issues play media on the ipad
native media player
what is native player
what is the native media player on iphone?
when is ifunbox io6
