How could we connect an iPad to a screen, a monitor or a projector?
This is a discussion on How to connect an iPad to a monitor? within the iPad General Discussions forums, part of the Apple iPad Discussions category; How could we connect an iPad to a screen, a monitor or a projector?...
You need to get an adaptor
Apple Store to the cables section http://store.apple.com/uk/browse/hom...s/cables_docks
Thank you, I suppose I need an Apple VGA adapter.
Yes, the VGA one is the way to go. You will need a regular VGA cable as well, if you don't already have one.
dhewson777
Brisbane, Australia
iPad 2, iPhone 4, MBA 11"
Yes, I have windows PCs as well! (too many to list)
I forgot to ask one thing. In Windows system we need to press some function key to get the signal to go to the projector or screen only or to repeat or to expand the screen. Do I need to do the same?
If i remember correctly, what you see on the ipad screen is what is displayed
I'm planning to purchase an Apple TV to experiment with connecting my iPad wirelessly to my projector so I can move about a room. I use my iPad connected to my projector in almost every class I teach and having the iPad tethered to a projector by a cable is often awkward.
Does the projector have an hdmi connection? then you jist need to hook up apple tv to projector and thenyou can wirelessly project from ipad to apple tv to monitor. look for the airplay symbol next to videos, websites,documents. very easy to do. no need to tether with a cable. if no hdmi connection to monitor, you will need adapter. hdmi to vga.
Thank you for your advice. I'm going to need that adapter because my projector doesn't have an hdmi port.Originally Posted by rbtanderson
