Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By emuesch
Thread: Problem charging the battery
    242619
    Sep 2012
    Hi,
    I've been using the iPad for almost a year now and have faced a problem with it for the first time. I'm trying to charge the battery by plugging it in using the original Apple able and adaptors, however the tablet just isnt recognising the power source or charging. Any assistance about this would be much appreciated
    Cheers,
    Zam
    iPad Ninja
    237846
    143 times
    Aug 2012
    California, USA
    2,482
    Have you tried switching chargers/cables, Zam? I once had a problem with my iPad similar to yours, and the issue was resolved by switching USB cables.
    Regards, From the computing device of Goofy8275, iPadForums.net user
    Origin ID (for Simpsons Tapped Out): ipadpronto
    Game Center ID: iPForum, Hay Day level: 38. (I am less active on Hay Day so don't be surprised if your friend request isn't fufilled)
    Forum rules: http://www.ipadforums.net/forum-rule...ease-read.html
    240754
    Aug 2012
    This has happened to me several times. Once it was because the power strip i was plugging into was toggled in the off position. Another time it was because the cable wasn't completely plugged-in to the adaptor. The last time it was because the adaptor, which is actually two pieces (at least mine is), had slipped apart a tiny bit and I had to slide the USB piece back into the prong piece.
    If your issue isn't any of those then post a bit more detail about the situation you are facing. Have you used this particular charger and cable before for this particular iPad? Have you tried another outlet in your home/office?
    Also, try resetting the iPad (press Home and Sleep and slide the slider, wait 30 secs and turn back on) and see if that helps after you turn it back on.
    goofy8275 likes this.
    2888
    48 times
    Apr 2010
    Fort Wayne, IN
    1,221
    Quote Originally Posted by emuesch
    In this case, I would skip turning on the iPad. Instead I would plug the cable back into the iPad as it comes on anyway.
    Moderator
    131244
    729 times
    Dec 2011
    Regina,Canada
    15,090
    Quote Originally Posted by ZammyBoi
    Hi,
    Cheers,
    Zam
    If you have any other iDevices, try using the charger on them, if the other devices don't charge, then the charger, cable or both are likely defective. If the charger works with other devices then maybe there is a defect in your iPad. Your iPad is under warranty for one year after purchase so take it to the nearest Apple store or authorized service center and have it checked out. If it is defective it will be replaced at no charge as long as the warranty hasn't expired yet. Make sure to do a backup of your iPad before taking it in, then set up the replacement from the backup you made.
    P.S., your charger and cable are also covered by the warranty so if they're defective you can get them replaced.
    Moderator
    131244
    729 times
    Dec 2011
    Regina,Canada
    15,090
    Another thought here. Have you checked that the outlet you plug the charger into is live?
  1. Charging the battery
    By Drofpets in forum iPad 3 Forum
    Last Post: 09-19-2012, 03:42 PM
  2. Ipad3 charging battery problem
    By bettyg in forum Siri for the New iPad
    Last Post: 08-23-2012, 06:23 AM
  3. iPad NOT CHARGING Battery Problem Fix
    Last Post: 01-22-2011, 01:56 PM
  4. Charging a New Battery
    By Solaris in forum iPad General Discussions
    Last Post: 11-03-2010, 09:20 AM
  5. Battery charging
    By Seadog in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 07-05-2010, 09:29 PM
battery problems
ipad not charging from macbook
