Ipad 3 charging problems (newbie)
This is a discussion on Ipad 3 charging problems (newbie) within the iPad General Discussions forums, part of the Apple iPad Discussions category; Hi all I bought myself a iPad 3 yesterday after running the battery flat I went to charge it using my I phone charger but ...
Results 1 to 10 of 10
    240278
    Aug 2012
    Sheffild
    Hi all I bought myself a iPad 3 yesterday after running the battery flat I went to charge it using my I phone charger but took ages just to do a couple of percentage, then it was time for work come to plug it into my car charger and it is saying "not charging", great forum this is, any help and advise would be great full, thanks all
    Moderator
    131244
    646 times
    Dec 2011
    Regina,Canada
    14,723
    Quote Originally Posted by Gordk
    You should charge your iPad with the supplied charger. If you charge it with an iPhone charger, it will take much longer than if you use the proper iPad charger because it has a lower power output.
    The iPhone charger will charge your iPad, but only if it is in sleep mode. The same thing applies to your car charger.
    iPad Ninja
    237846
    143 times
    Aug 2012
    California, USA
    2,481
    Quote Originally Posted by Gordk View Post
    It sound like you are using an iPhone charger. Use the charger that came with your iPad.
    Regards, From the computing device of Goofy8275, iPadForums.net user
    Origin ID (for Simpsons Tapped Out): ipadpronto
    Game Center ID: iPForum, Hay Day level: 38. (I am less active on Hay Day so don't be surprised if your friend request isn't fufilled)
    Forum rules: http://www.ipadforums.net/forum-rule...ease-read.html
    240345
    Aug 2012
    6
    220553
    12 times
    Jun 2012
    Devon, UK
    154
    Quote Originally Posted by pattimang View Post
    Not very well & the ipad may even damage the iphone charger. The ipad charger is 5v/2a=10w. The iphone charger is 5v/1a=5w AFAIK.
    240278
    Aug 2012
    Sheffild
    Thanks for the replies, when I got home from work I plugged the proper iPad charger in and used that, I was just been a bit eager to get going with it. Does anybody know if there is a car charger for the new iPad? I'm a truck driver so sometimes may need to charge on the go
    iPad Ninja
    237846
    143 times
    Aug 2012
    California, USA
    2,481
    Yes, but much slower!
    Moderator
    131244
    646 times
    Dec 2011
    Regina,Canada
    14,723
    Quote Originally Posted by goofy8275
    And not if you try to use the iPad at the same time.
    220553
    12 times
    Jun 2012
    Devon, UK
    154
    Gord, why not get an inverter. Useful for lots of stuff. A low power 150w one that plugs into your 12v cab socket would suffice. Cost, around £10 eg Car 150W Real Power inverter 12V DC to 220V AC Output USB NEW | eBay
    And then a spare iPad charger, eg Nanobits UK 10W Mains Charger for Apple iPad and Apple iPad 2 2A (2000mA) CE Approved: Amazon.co.uk: Computers & Accessories
    Or a PowerGen Power-U Dual USB 2A 10W Heavy Duty Ouput Car Charger for Apple iPad 2, New iPad 3, iPhone 4 4s 3Gs 3G, iPod Touch (USB cable NOT included) - White: Amazon.co.uk: Electronics & a spare cable...
    High Grade - Extra Long USB Sync & Charge Cable for: Amazon.co.uk: Electronics
    Couple of ideas there, at least.
    186502
    4 times
    Apr 2012
    61
    Go to amazon or radio shack and get a car charger that is rated for two amps and all will be well. The ones you are using are only capable of around .5 to .75 amps which won't fit it. Much better than a expensive inverter.
    P. S. I have three, two cars and RV and they charge fine.
  1. Charging problems
    By Dianeleslie in forum iPad Help
    Last Post: 08-11-2012, 04:33 AM
  2. Charging problems
    By Kaelib in forum iPad Help
    Last Post: 08-05-2012, 04:12 PM
  3. iPad charging problems
    By bunnyharriet in forum iPad Help
    Last Post: 01-21-2012, 09:39 AM
  4. Charging Problems
    By Remi in forum iPad Help
    Last Post: 02-10-2011, 12:23 AM
  5. Ipad newbie...newbie problems
    By piper109 in forum New Member Introductions - Site Assistance
    Last Post: 12-19-2010, 10:58 AM
how to use the charger for charging ipad3
ipad 3 charging issues
ipad 3 charging problem
ipad 3 charging problem (not charging)
ipad 3 charging problems
ipad 3 charging walt
ipad 3 not chagring after going flat
ipad 3 not charging
ipad 3 only came with 5w charger?
ipad charge problems car
ipad charging problems
ipad3 runs flat on charger
