Need Help Please...
This is a discussion on Need Help Please... within the iPad General Discussions forums, part of the Apple iPad Discussions category; Ipad3 (3g)... Went to General then tapped on Reset so as able to put back Itunes app that i deleted (as i'm not in to ...
Results 1 to 4 of 4
    238959
    Aug 2012
    Need Help Please...
    Ipad3 (3g)...
    Went to General then tapped on Reset so as able to put back Itunes app that i deleted (as i'm not in to music) so as able to download an app that is over 50MB, i didnt know that Itunes store enables you to download apps. then tapped on Reset All Settings, long story short got my Itunes app back but cannot reconnect to the internet, have full signal strength, small diaglog box comes up say'n "Could not activate mobile data network" "PDP authentication failure" tapped OK then small diaglog box takes place of previously stated box say'n "Cannot Open Page" Safari cannot open page because it is not connected to the internet"....
    Anyone with any ideas?, if not will just take it down to the place of purchase Monday...
    Oh please keep in mind, i'm not the worlds smartest with these things either.
    172732
    8 times
    Mar 2012
    333
    Is cellular data turned on?you may need to configure your data apn settings.
    238959
    Aug 2012
    Thanks heaps, i just rechecked my apn number and it was only similar and not the same as given upon purchase, so thankyou very much all sorted.
    172732
    8 times
    Mar 2012
    333
    Peace.
pdp
was able to download over 50mb from app store
