iTunes: How to change sync settings without connecting device?
This is a discussion on iTunes: How to change sync settings without connecting device? within the iPad General Discussions forums, part of the Apple iPad Discussions category; I need to stop itunes from syncing my contacts. But to do this, I need to edit the sync settings before i plug the device ...
I need to stop itunes from syncing my contacts. But to do this, I need to edit the sync settings before i plug the device in. But those settings arent available until after youve plugged the device in.. chicken, meet egg. Any ideas on how to do this?
08-15-2010 01:11 AM
iPad Master!
I suggest you load up iTunes, connect your device, and then immediately swipe the screen when it comes up with message "swipe to cancel sync" (not sure if that's the precise wording). Bingo, you can change your settings and then manually sync.
iPad wifi + 3G 64GB
Paired with Macbook Pro
I remember that the Application preferences of iTunes(CMD+,) has got a panel to configure the devices, including an option to choose whether or not sync automatically when the devices connect.
But this was on a Mac, not sure if the PC version works the same way.
Yes, PC works the same way.
- You may not post replies
- You may not edit your posts
Forum Rules
By hayder in forum iPad Hacking
Last Post: 08-11-2010, 01:13 PM
By mkrowkis in forum iPad Hacking
Last Post: 08-11-2010, 12:17 PM
Last Post: 08-08-2010, 02:40 PM
By Rogner in forum iPad General Discussions
Last Post: 06-23-2010, 08:52 AM
By kl281071 in forum iPad FAQ
Last Post: 06-16-2010, 10:20 AM
adjust sync settings itunes
change ipad sync settings
change itunes sync settings
change sync settings in itunes
change sync settings itunes
changing sync settings in itunes
connect ipad without syncing
how do i edit the syncronization option from itunes
how to adjust sync settings itunes
how to change itunes settings
how to change itunes sync settings
how to change settings on itunes
how to change sync setting on itunes
how to change sync settings in itunes
how to change sync settings on itunes
ipad sync settings
itunes device settings
itunes settings on ipad
itunes sync options
