Why does wifi connection slow down at times?
This is a discussion on Why does wifi connection slow down at times? within the iPad General Discussions forums, part of the Apple iPad Discussions category; Yet my desktop doesn't have this problem. The iPad connection slows down at times and videos do not load up when these problems occur. However, ...
Results 1 to 10 of 13
    1148
    Mar 2010
    142
    Yet my desktop doesn't have this problem. The iPad connection slows down at times and videos do not load up when these problems occur. However, the web browser (Safari) seems to work OK but a little slower than usual at those times.
    My broadband connection at home is pretty fast with speeds of around 7mb. And teh problems occur even when I am quite close to the router itself. Yet other times I could be in the back garden and there would be no problems.
    Is the problem with the iPad wifi?
    iPF Super Guru
    7401
    8 times
    Jun 2010
    4,239
    The latest software version is 3.2.1 and it has been known to improve troublesome WiFi connection problems.
    5353
    5 times
    May 2010
    Fort Worth, TX
    663
    It could also be interference. Some cordless phones, microwaves and other wireless things in your house could affect the reception.
    10539
    Jul 2010
    Va
    121
    I second the interference. Try changing the broadcast channel on your router to something obscure like channel 8 or 3, something not many routers in your area are likely to broadcast on.
    iPad 64GB WiFi OS 5.0.1
    10539
    Jul 2010
    Va
    121
    Also you can squeeze a bit more speed out of it by only broadcasting 802.11g intend of supporting all formats (g AND N) if you don't have any "N" devices this make a lot of sense to do. (yes, the iPad is 802.11n capable.)
    Another thing to try is to relocate your router to a middle point in your home to get better coverage. Hope that will help you!
    iPF Super Guru
    7401
    8 times
    Jun 2010
    4,239
    Another thing to ask... is there anyone else in your home using your Internet connection? When my wife is on her computer and our daughter is on hers, that can really slow things down when several users are connecting through the same device at the same time.
    3851
    19 times
    May 2010
    Miami, FL
    2,366
    The internet itself is not constant. There are thousands of factors that determine your speeds at any given time.
    1148
    Mar 2010
    142
    I can tell there is a problem with wifi on my iPad. It happens from time to time but is an inconvenience when it does happen. Like I said earlier, the same problem does not occur with my desktop or the laptop when I was using that.
    Where I can I download the softwre update that's supposed to improve wifi reception on the iPad?
    iPF Super Guru
    7401
    8 times
    Jun 2010
    4,239
    You have to connect your iPad to your computer and run iTunes. If it does not automatically tell you there is an update, you can click on Check for Update.
    Once iTunes is open, select your iPad under Devices and check the Software Version number. If it is NOT 3.2.1, click on the Check for Update box and it will tell you that an update is available and you will have the choice to ignore it, download it but not install it or download it and install it. It could take some time to download the update and install it, so you will want to do this when you are willing to be without your iPad for at least 30-45 minutes (or more).
    11232
    Aug 2010
    tampa fl
    59
    I had the exact same symptoms. Turned out to be a neighbor using the same WiFi channel. Try switching channels.
  1. Wifi connection slow and unpredictable
    By DMad in forum iPad Help
    Last Post: 12-15-2010, 01:34 PM
  2. WiFi Connection Issues with iOS4
    By e1allen2 in forum Off-Topic
    Last Post: 09-16-2010, 11:12 PM
  3. Keep losing wifi connection
    By Dpeach in forum iPad Carriers
    Last Post: 06-29-2010, 06:28 AM
  4. Wifi connection drops solution!
    By Itzxdjx in forum iPad General Discussions
    Last Post: 04-18-2010, 01:17 PM
  5. Has anybody else been having intermittency with WiFi connection?
    By djpritchard in forum iPad General Discussions
    Last Post: 04-10-2010, 03:47 PM
does hardline slow down wifi?
how to keep cell phone from slowing down my home wifi modem
ipad is slow at night
what slows down wifi
why does my ipad slow down at night
why does wifi slow down
why is my ipad slowing down
why is my wifi slow at night
