itunes streaming from pc to ipad2 wireless over home network
This is a discussion on itunes streaming from pc to ipad2 wireless over home network within the iPad General Discussions forums, part of the Apple iPad Discussions category; I have iTunes installed on my windows 7 pc. How do I open the library on my iPad to play into another stereo system? I ...
Results 1 to 10 of 20
    215397
    Jun 2012
    9
    I have iTunes installed on my windows 7 pc. How do I open the library on my iPad to play into another stereo system? I can't open iTunes on my iPad other than go to the store.
    180113
    Mar 2012
    89
    Download the Apple Remote app from the app store. With iTunes running on your PC you will need to insure you "turn on home sharing" under the advanced settings tab in iTunes. Once done you can access all your iTunes media on the iPad via the Apple Remote app provided your PC and iPad are on the same WiFi network. iTunes has to be running on the PC thou during the streaming from your PC to the iPad.
    180113
    Mar 2012
    89
    itunes streaming from pc to ipad2 wireless over home network-image-54042261.jpg
    This is the Apple Remote app.
    1546 times
    Walla Walla, WA
    15,471
    iTunes on the iPad is only for purchasing stuff. To play your music use the Music app.
    215397
    Jun 2012
    9
    Test
    215397
    Jun 2012
    9
    Ok, this noob installed the remote app. I can now see iTunes on the iPad. I hit play, the player scrolls the timeline of the song, but no audio. I DO have audio in other apps like Air Video. I'm sure I'm missing a setting somewhere. Where would that be,please.
    1546 times
    Walla Walla, WA
    15,471
    The remote app controls the music (in iTunes) on the computer, using the computer's speakers (or other connected audio device).
    To play your computer's iTunes library on the iPad you use Home Sharing.
    iOS: Setting up Home Sharing on your device
    46070
    53 times
    Egremont
    979
    You don't need the remote app, thats for control of your itune library on your PC so it will output audio from whatever the pc is connected to, unless you connect your pc to your hifi, then it is what you want.
    For payback on the ipad (or anything its connected to) use homesharing, turn homesharing on in itunes on PC and ipad and then use the music app and press the more button then Shared and your itunes library should appear.
    215397
    Jun 2012
    9
    My iTunes library is seen on the iPad. I can also see that the song is playing. No audio out of the headphone jack. All the sharing settings seem correct. Just
    no audio.
    1546 times
    Walla Walla, WA
    15,471
    Somethings to try, if you have not already.
    1) Make sure you've turned the volume up. The iPad keeps different volume leves for the headphone and speaker, so do expect it to play just because the speaker did.
    2) Make sure the headphones are firmly seated. It's easy to think they are, especially if you have a cover, and the jack gets caught on the edge.
    3) In Settings > Music, check your Volume Limit setting.
    4) While it should not affect Music playback, you should also check to make sure you are not muted. This can either be the slide switch next to the volume rocker, or in the multitask bar (double tap home and slide the icons to the right). The settings are here: iPad: Understanding the side switch
    5) It never hurts to restart the iPad, or reset if that does not work.
  1. Replies: 2
    Last Post: 04-07-2012, 09:52 PM
  2. Home network dramas
    By Macca1959 in forum New Member Introductions - Site Assistance
    Last Post: 03-12-2012, 06:27 PM
  3. Home Network Security
    By MacMama in forum iPad 2 Forum
    Last Post: 01-15-2012, 12:02 PM
  4. Problem connecting to wireless home network
    By colinicky in forum iPad 1 Forum
    Last Post: 01-02-2012, 09:54 AM
  5. Set up on Home Network
    By Rick K in forum iPad General Discussions
    Last Post: 05-21-2011, 07:18 AM
how to stream music from pc to ipad 2
stream de audio ipad to pc wireless
stream from pc to ipad 2
stream itunes to ipad 2
stream to ipad from pc
streaming from pc to ipad 2
streaming pc to ipad
