connection problems
This is a discussion on connection problems within the iPad General Discussions forums, part of the Apple iPad Discussions category; I need help trying to understand why my ipad 2 won't connect to my home WiFi. It shows its connected but won't work. I have ...
Results 1 to 4 of 4
    179745
    Mar 2012
    9
    connection problems
    I need help trying to understand why my ipad 2 won't connect to my home WiFi. It shows its connected but won't work. I have reset the ipad, checked the router with a laptop to see if its working, and contacted the ISP. Any suggestions?
    118965
    Oct 2011
    Sin City
    78
    Check the IP address. Our router occasionally assigns them outside the allowed range. We don't know why, but it means we appear connected, but can't go anywhere. We assign the IP address manually based on the MAC address of the device. Fixes it every time.
    179745
    Mar 2012
    9
    thank you for responding its working now
    33574
    24 times
    Feb 2011
    Levittown pa
    678
    Quote Originally Posted by MRCONYERS
    @@@@@@@@@@ I see you are good to go. Will leave this post for future reference. @@@@@@@@@@@
    How are you testing for connectivity ? When you look at the wifi connections details do you have an ip address?
    When you open safari what happens? What error if any is generated?
    Can you access the app store? iTunes? You tube? Can you send/receive email?
    If ANY of the above functions are working you likely are connected but I would suggest checking restrictions to see if you accidentally restricted yourself from some basic functions.
    If ipad restrictions are indeed off and NONE of the above are working I would ask you to post a screenshot of your wifi connection details like the one I have provided below so we can further troubleshoot your issue. It is feasible that your wifi router may have some customized settings that are limiting your ability to access anything outside your home LAN. It takes a level of technical ability to customize a home network and use VLANS, setup access rules, port forwarding, a DMZ, etc.
    If you are receiving a valid IP address there are some things we can do to determine what level of connectivity you have and if you are getting past the router. Let's cross that bridge if we come to it.
    A common first level fix is to tell the iPad to forget the problem connection, restart the iPad and rediscover it. So please check restrictions, progress to rediscovering the access point if restrictions aren't the issue, and finally post a screen shot of the connection details if you still have an issue.
  1. 3G connection problems
    By simoncoulthurst in forum UK Dedicated iPad Forum
    Last Post: 05-03-2012, 03:08 AM
  2. Connection problems
    By ukpouchies in forum iPad Help
    Last Post: 12-03-2011, 11:11 AM
  3. PC connection problems
    By turner in forum New Member Introductions - Site Assistance
    Last Post: 11-06-2011, 07:07 AM
  4. Connection Problems
    By Al Rogers in forum iPad Help
    Last Post: 01-04-2011, 06:38 PM
  5. connection kit problems
    By samsberr in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 06-14-2010, 05:32 PM
ipad connection problems
port close
troubleshoot connecting ipad to stereo
