iPad WiFi Connection Problems
This is a discussion on iPad WiFi Connection Problems within the iPad General Discussions forums, part of the Apple iPad Discussions category; I have the new iPad (64gb, 4G). I have noticed that, at times, my iPad has problems connecting to the WiFi. This does not happen ...
Results 1 to 10 of 13
    187411
    Apr 2012
    19
    I have the new iPad (64gb, 4G). I have noticed that, at times, my iPad has problems connecting to the WiFi. This does not happen that often, but when it does it is annoying and puzzling. Here are the specific symptoms of the most recent occurrence. My iPad always automatically detects my home WiFi connection. I turned my iPad off for the night. When I turned it on the next morning, it would not connect to my wifi. I checked my pc to see if there were any wifi connection problems, but my pc was connected and working properly. I clicked on the wifi tab and saw the name of my wifi connection listed. However, my iPad would not connect to it. Luckily I have a 4G connection as well. Has anyone else experienced this problem? Or, does anyone know what may be causing this problem?
    Moderator
    131244
    624 times
    Dec 2011
    Regina,Canada
    14,522
    Have you tried turning the WIFI off,then on again to see if it helps?
    iPad Ninja
    49414
    80 times
    North Carolina
    1,925
    Hi Davey123 - probably already done, but you can look in the 'Wi-Fi Settings' to make sure your home network is listed; of course, you could 'Forget the Network' and have the iPad re-detect the Wi-Fi router?
    Second, you could 'Reset' the iPad (you've already done a 'Restart' by turning the device On & Off) - finally, you could power recycle your modem and router, i.e. turn each off (or pull their power plugs); then in sequence, turn the modem on first and then the router - I have to do this about once a month w/ my home network.
    Good luck and let us know if any of these suggestions help -
    187411
    Apr 2012
    19
    Thanks for the feedback. As I mentioned, this problem does not occur frequently. When I turned my 4G on and turned it back off, then the problem had corrected itself. I will try to turn off my router the next time the problem occurs. It is strange because my pc still detected the wifi network, although my iPad didn't. Also, I was just wondering if others had experienced a similar type of problem. Again,thanks.
    189809
    Apr 2012
    22
    194512
    Apr 2012
    salvador
    My Ipad2's wifi is not connecting in my house. It connects everywhere but not here. My computer is connected, no problem, but the ipad doesn't. It sees the network, asks for password, the wifi bar shows up full but the connection is never completed.
    194554
    Apr 2012
    Quote Originally Posted by davey123
    I had the same problem everything you mentioned happened to me. To make it short and sweet my I pad 2 was still under a year old. Apple exchanged for a new no questions. Brilliant service
    79622
    8 times
    Jul 2011
    Pelican Island, NJ
    283
    I would say if the problem persists, make an appointment with the genius bar. Can't hurt, right?
    Good luck and I hope you are able to get the issue resolved quickly
    ~~32GB iPad3~~16GB iPad1~~80GB iPod Classic~~iPhone 4~~
    iPad Ninja
    49414
    80 times
    North Carolina
    1,925
    Quote Originally Posted by sergio. View Post
    Hi Sergio - welcome to the forum!
    Not certain if you looked at my previous post closely, but I would suggest that you 'power recycle' your modem & router (explained before) - despite your computer not having an internet connection issue, other devices on the network may not function properly - good luck!
    211039
    May 2012
    Israel
    My Ipad 2 64GB 3g WiFi is having continous connection problems - I connect to my home WiFi and it is good only for a few minutes. There are 5 Ipads in my home and all the others have continuous connection. It is driving me bonkers especially after I write a long message and as I press send I get "No internet connection" and I have to go to settings to reconnect (also for a few minutes) and the whole message is wiped out.
  1. Replies: 50
    Last Post: 10-12-2012, 10:42 PM
  2. Problems with wifi connection
    By hinke00 in forum iPad 2 Forum
    Last Post: 11-01-2011, 06:25 PM
  3. Had or having IPad 2 wifi connection problems?
    By drb_52 in forum Apple iPad Polls
    Last Post: 08-15-2011, 02:50 AM
  4. Replies: 3
ipad auto connect to wifi
ipad does not always connect
ipad does not ask for wifi password
ipad does not connect to wifi automatically
ipad doesn't connect to wifi
ipad doesn't recognize wifi password
ipad doesn't want to connect to wifi
ipad not automatically connecting to wifi
ipad not connecting to wifi at home
ipad wifi not connecting automatically
my ipad doesn't connect to wifi
my ipad doesn't connect to wifi automatically
