How OCD are you about the battery level?
This is a discussion on How OCD are you about the battery level? within the iPad General Discussions forums, part of the Apple iPad Discussions category; My home has 6 different places to charge. I know some of you are care-free about letting it run down this thread is for the ...
Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 34
    179012
    5 times
    Mar 2012
    229
    My home has 6 different places to charge. I know some of you are care-free about letting it run down this thread is for the obsessed which I doubt I am the only one.
    Obviously nothing makes me happier than 100 percent.
    When I fall below 60 I find myself thinking about the battery more.
    Below 50 and I am really thinking about charging.
    Below 35 and I am nearly panicked.
    Below 20 and I will knock people over if they are between me and a charger.
    Below 10 and the nice men in white outfits have to restrain me.
    I do run them down from time to time but it always bothers me.
    186862
    Apr 2012
    46
    Quote Originally Posted by beesknees
    I charge mine when it gets below 10..doesn't bother me one way or the other..if it runs out so be it..
    64 gb ipad2 in black
    139850
    20 times
    Dec 2011
    Denver, CO
    639
    Quote Originally Posted by beesknees View Post
    LOL, I do what I can to help maximize by battery life and longevity of battery itself but I do not go too crazy about it. I fully drain it about once a month then usually charge it when it gets between 40-80 percent (if I can), but sometimes I forget so it drains lower when I am using it out and about so then I tend to conserve more. I do get paranoid when I travel though. Kind of funny, I am so worried about draining it that I end up hardly using it on flights and stuff. Even though that is the most entertaining things to do while traveling.
    iPhone 4s 64GB White (Jailbroken), The "New iPad" 16GB Black (Stock), Past devices: iPad 2, HTC Hero, HTC Evo, HTC Evo 3D, ASUS Transformer.
    49720
    417 times
    SC
    6,342
    I have two charging stations at home, one at work and one in my car. For both the 4S and iPad 3.
    I don't think my iPad has ever been south of 50%. My phone has because I use certain apps that keep the screen on almost continually for a period of time, which drains the battery. When I am at my desk, something in on charge.
    Oh...I forgot about my iPad Nano, which is my watch. It gets in the charging mix from time to time.
    mini iPad w/ RD - 128 LTE - Space Grey | iPhone 4S - 64GB - White | Nexus 10 | Nexus 7 2013 | Kindle Fire
    * * * Forum Rules * * *
    179012
    5 times
    Mar 2012
    229
    Quote Originally Posted by bmahony
    I'd be under my desk in the fetal position twitching uncontrollably.
    174129
    Mar 2012
    Cyprus in the med
    78
    Down to 15% just now , off to bed soon so on charge it will go overnight . Yes it does make you keep an eye on it when it is getting low. When I am on a flight I make sure it is fully charged before I go to the airport but do not turn it on until I am on board.
    183807
    6 times
    Mar 2012
    76
    Does the iPad battery not have "memory" issues like other rechargeables? I'm always concerned about charging it when it is not fully discharged.
    Sent from my iPad3 using iPF
    175844
    14 times
    Mar 2012
    Vancouver
    466
    Quote Originally Posted by drathbun
    No the iPad and most modern gadgets do not have memory issues (No not at all).
    You do have to discharge it occasionally to recalibrate the software on the battery that shows how full it is.
    If you store you device without use for a long time leave it with battery charged at 40%. Leaving it discharged completely for weeks could kill the battery.
    183807
    6 times
    Mar 2012
    76
    Quote Originally Posted by zphone
    Good info thanks!
    189809
    Apr 2012
    22
    Quote Originally Posted by drathbun View Post
    Good info thanks!
    Very.
    I've seen battery-life significantly affected by treatment. While Apple has a good charger, based on the battery technology used, good tips are:
    O Don't let battery run out on a regular basis.
    O Especially, don't leave battery fully discharged.
    O Don't overcharge - even with a good charger, leaving on charger for long periods is bad mojo.
    O Don't charge in high heat, or with heavy case on.
    O Don't use while charging.
    Each bullet above has it's basis in detailed engineering papers on the li-ion (polymer) iPads use. The recommendation to discharge monthly is for battery indicator accuracy, not battery life.
  1. modern war, higher level building in lower level bases?
    By toonboy78 in forum Modern War Forum
    Last Post: 02-06-2013, 11:41 AM
  2. Battery Level Reading
    By AQ_OC in forum iPad 3 Forum
    Last Post: 03-22-2012, 06:09 PM
  3. Replies: 3
    Last Post: 03-18-2012, 03:22 AM
  4. N.O.VA. 2 level 5
    By iJosh in forum iPad Games
    Last Post: 04-13-2011, 04:32 PM
  5. Battery level indicator?
    By Checkpoint in forum iPad General Discussions
    Last Post: 08-02-2010, 06:11 PM
battery level ocd
battery percentage on iphone 4s makes you paranoid?
does ipad 3 battery have a memory
does ipad 3 battery have memory
does ipad battery have memory
extending ipad memory
ocd batter
ocd battery
