iPad charger vs iPhone charger...
This is a discussion on iPad charger vs iPhone charger... within the iPad General Discussions forums, part of the Apple iPad Discussions category; Is there a difference? I assume that the iPad charger is more powerful, but I'm only guessing. Is it OK to use my iPad charger ...
Results 1 to 2 of 2
    182325
    4 times
    Mar 2012
    San Diego
    98
    Is there a difference? I assume that the iPad charger is more powerful, but I'm only guessing. Is it OK to use my iPad charger to charge my iPhone? And vice versa?
    Also has there been a change in iPad chargers in power hroughhe generations? I have an iPad1 and 3.
    I assume they're the same chargers in power?
    |iPhone5 32GB | 4th gen iPod touch 8GB | 4th gen Shuffle 2GB | iPad Mini1 32GB | iPad3 16GB 4G | Apple TV (gen 3) | 160GB Classic | iPhone 4 | 6th gen 8GB Nano | iPad1 32GB 3G | 4th gen iPod touch 8GB | 2nd gen iPod touch 16GB | 3rd gen iPod 10GB | 5th gen iPod 60GB | 2nd gen 2GB Nano | 1st gen 4GB Nano | 1st gen 1GB Nano | 2nd gen Shuffle 1GB | 3rd gen 8GB Nano | 1st gen Shuffle 512MB |
    iPad Ninja
    49414
    80 times
    North Carolina
    1,930
    Hi XD... - welcome to the forum!
    Chargers produce POWER, i.e. wattage which is Voltage x Amperage - the iPad charger is 10 watts (i.e. 5V x 2Amps); the chargers for the iPhone & iPod are 5 watts (i.e. half the amperage) - but to answer your question, YES there is a difference - you need the more powerful wattage for the iPad (despite a trickle charge w/ the lower wattage chargers which will shows that your iPad is NOT charging); OTOH, you can certainly use the iPad charger for your iPhone & iPod (I do the latter often) - hope this helps -
  1. iPad charger to use on Iphone
    By Boblins in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 01-05-2012, 02:39 AM
  2. Using iPhone charger on iPad???
    By M325i in forum iPad General Discussions
    Last Post: 07-24-2011, 08:30 PM
  3. Looking for iPad+iPhone charger
    By Involute in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 07-18-2011, 01:35 AM
  4. Can I use iPad charger on iphone
    By macfoot in forum iPad Help
    Last Post: 03-27-2011, 04:04 PM
  5. iPad charger verses iPhone charger
    By iPadster in forum iPad General Discussions
    Last Post: 01-05-2011, 02:09 PM
can you use an ipad charger with iphone
ipad and ipod charger
ipad charger vs iphone charger
ipad charger vs ipod charger
ipad with charger
iphone charger vs ipad charger
iphone vs ipad charger
ipod charger vs ipad charger
ipod ipad charger
is ipad charger ok for iphone
is it ok to use an ipad charger on an iphone
is it okay to use an iphone charger on an ipad?
