Problem with charging ipad...
This is a discussion on Problem with charging ipad... within the iPad General Discussions forums, part of the Apple iPad Discussions category; When I plug in my iPad it usually turns on then I shut it off and it charges all night. Now I plug it in ...
Results 1 to 10 of 13
    87210
    Aug 2011
    6
    When I plug in my iPad it usually turns on then I shut it off and it charges all night. Now I plug it in and it does not turn on and it does not charge. I have tried several different outlets, but none of them work. Does anyone know how to fix this problem for me before my battery is completely dead? Thank you!
  2. #2
    13576
    218 times
    Aug 2010
    Western NY state (USA)
    5,114
    I am going to assume you are using the same charger and cord you've used in the past? And, that you've tried a different charger and/or a different cord, along with trying different outlets?
    Given those two assumptions, there's not much we can advise, given that you're describing what appears to be a hardware fault. You can try the two "stand bys" for when the iPad is acting weird, restart and reset (or both). To do:
    Reset: Hold both the power and home buttons until the screen goes dark and the Apple logo then appears (the slide to unlock screen may or may not appear). Once the logo appears, release the buttons. After a time, your homescreen will appear. Please note that it may take some time for the Apple logo to appear or for your homescreen to appear (or both). This is normal. Eventually, the homescreen will appear.
    Oh, and have you tried to see if it charges with your computer? <--- Yeah, it'll say it's not charging, but there is a tiny trickle charge when the iPad is connected to a computer and, if you don't use it, it will charge, albeit v-e-r-y slowly.
    Other than that, it sounds as if you need to take it to the Geniuses at the Apple Store and have them physically look at it. Sorry.
    Black 64GB WiFi/4G iPad3 (iOS 5.1.1; jailbroken w/Absinthe 2.0) & black 64GB iPhone 4S (iOS 5.0.1; jailbroken w/Absinthe 1.0)
  3. #3
    87210
    Aug 2011
    6
    I am using the original charger that comes with the iPad. And yes I tried different outlets. I will try the resets tonight when I go to charge. Plus I just noticed my battery is staying at 96%
  4. #4
    52417
    17 times
    May 2011
    Dorset, United Kingdom
    257
    Quote Originally Posted by starbie
    This is just speculation as what I'm about to type doesn't account for why your iPad isn't being charged but apple do recommend that you perform a battery cycle (totally drain, totally fill) once every month in order to keep the battery %age calibrated. Probably not much help but it might be an explanation as to why your %age is stuck at 96.
    Sent via iPF from my iPad.
  5. #5
    153195
    2 times
    Jan 2012
    east islip
    139
    so when i get my ipad 2 after its fully charged i just use it till it's drained?? then recharge it. i do this with my cell phone&playstation 3 contoller anyways let it totaly drain then i will recharge it when its dead.
    but most of the newer batterys dont need to be drained because they dont have a memory like the old NiCad did .. what kind of battery is in the ipad 2
  6. #6
    87210
    Aug 2011
    6
    I just plug it in every night, I never wait until the battery is dead. I figured for the price I payed for this sucker the battery could be charged at anytime!
  7. #7
    iPF Elite
    176 times
    Dayton, WA
    9,228
    Quote Originally Posted by tazz3 View Post
    Apple recommends you do it once a month, but it has nothing to do with battery life. It's just a way for the battery percentage indicator to recalibrate. And it is not so much the draining part they are after, but the uninterrupted recharge from near zero to 100%.
    I doubt this has anything to do with your problem. That sounds like your charger of cord have gone bad. While most computers don't do a good job of charging the iPad, if you shut it off and connect to a computer port it should recharge, though very slowly. This will at least let you keep if from dying until you can do something about the charger.
    Your iPad 2 is still under hardware warrantee, and I think the charger is included with that. You may be able to get a replacement for free (the charger, that is).
  8. #8
    87210
    Aug 2011
    6
    Well I powered down my iPad 1 and then I held the round button and hit the power button. Now the battery is draining normally. I will let it drain and try to recharge it then. Thank you so much for all of this info! I truly appreciate it!
  9. #9
    iPF Elite
    176 times
    Dayton, WA
    9,228
    Good. Let us know how it turns out.
  10. #10
    87210
    Aug 2011
    6
    Ok, I let the battery get really low last night then I plugged it in. It charged great. But I have one last question. do I wait to plug it in when it says battery is low plug it in, or must I wait until it is completely drained? Thanks for all of the help!
Sponsors
  1. iPad ios 5.0.1 Charging Problem
    By kingnba6 in forum iPad 1 Forum
    Last Post: 01-30-2012, 03:42 PM
  2. IPad 2 Charging Problem - Buzzing
    By Yorkshire Devil in forum iPad Help
    Last Post: 01-18-2012, 06:20 PM
  3. iPad 2 charging and synch problem
    By rlhiggins in forum iPad General Discussions
    Last Post: 10-04-2011, 07:54 AM
  4. iPad- Redsn0w Jailbreak charging problem
    By Andy512 in forum iPad Hacking
    Last Post: 03-05-2011, 03:19 PM
  5. iPad NOT CHARGING Battery Problem Fix
    Last Post: 01-22-2011, 01:56 PM
ipad 1 charging very slowly
ipad appears to be charging but isn't
ipad battery not holding charge
ipad charges all night but
ipad charging problems
ipad isn't charging on my computer
ipad not charging fix
ipad not holding charge
ipad not keeping charge
my ipad isn't charging
my ipad isnt charging
my ipad2 is not keeping a charge
recharge ipad
why doesn't my ipad charge when i plug it in
why isn't my ipad 2 charging
why isn't my ipad charging
why isn't my ipad charging when i plug it in
why isnt my ipad 2 charging
why isnt my ipad charging
whydoes my ipad charger on charge till it turns on
