Battery drained to zero!
This is a discussion on Battery drained to zero! within the iPad General Discussions forums, part of the Apple iPad Discussions category; I have an iPad 2 that has been great for the 3 months I own it. However, this morning I woke up to a fully ...
Results 1 to 2 of 2
    93181
    Aug 2011
    Florida
    58
    I have an iPad 2 that has been great for the 3 months I own it. However, this morning I woke up to a fully drained battery. It had the smart cover on it and it's like there was no sleep mode overnight. Any ideas as to why the battery drained down completely? I believe the iPad had around 88% of battery life last night. So, from 88% to zero overnight with the smart cover closed on it.
    Thanks for any input.
  2. #2
    iPF Elite
    176 times
    Dayton, WA
    9,228
    Keep an eye on it. If it does not happen again just mark it up to a fluke.
    Things that it might have been:
    If the smart cover was in a position to slide around a bit, it might turn the iPad on and off all night.
    Did you have a bluetooth keyboard paired and on. Might do something.
    If you started a large app download or other syncing process it could have continued part of the night, using up battery.
    Also, I'm not entirely convinced that an active (open) app will always shut down when the cover is closed. It may simply turn off the screen and keep running the app. I once thought I saw unusual battery drain on my iPad when I left Safari open to a webpage that automatically updated it's content; with the cover closed. I meant to test that more objectively, but because it would take a lot of time and planning I never have.
    To play it safe, always close the open app when you are finished with it. A few do have legitimate background tasks that can eat up battery.
Sponsors
  1. Ipad batter drained and won't charge
    By ryrenee in forum iPad Help
    Last Post: 12-04-2011, 01:29 PM
  2. iPad battery drained - apps not working
    By vonjoey63 in forum iPad Help
    Last Post: 07-05-2011, 12:39 AM
  3. Battery in IOS 4.2.1
    By skatealex2 in forum iPad OS
    Last Post: 11-29-2010, 07:07 PM
  4. how does the battery like this???
    By Spielor in forum iPad General Discussions
    Last Post: 10-29-2010, 12:52 AM
does ipad smart cover still drain the battery
how does the smart cover for the ipad not drain the battery
how to drain ipad battery to 0
ipad 2 battery drain
ipad 2 battery drain in sleep mode
ipad 2 battery drains overnight
ipad 2 draining battery sleep mode
ipad 3 battery drain standby
ipad 3 battery drin down to zero
ipad 3 smart cover battery drain
ipad battery completely drained
ipad battery drain
ipad battery drained
ipad battery draining overnight
ipad zero battery
new ipad battery drain overnight
running battery to zero ipad
smart cover battery drain?
smart cover drain battery
