iPad 3G as a in car GPS device
This is a discussion on iPad 3G as a in car GPS device within the iPad General Discussions forums, part of the Apple iPad Discussions category; With the cost of an installed in dash GPS /cd/radio unit coming close to 1000.00, i have decided to mount my iPad on the dashboard ...
1Likes
With the cost of an installed in dash GPS /cd/radio unit coming close to 1000.00, i have decided to mount my iPad on the dashboard for use as a GPS device. I found a device called the Padholder that is all of 99.00, and is easy to install. I am looking for others that use the iPad as a GPS device in their car. Please let me know how well it works.
01-15-2012 07:21 PM
From my experience here in indonesia, the built in map does not always accurate. I dont know if it's the map or the service provider, but "my location" icon shows text like, "accurate within radius 1900 m", or something similiar, and it really happens, which mean the map shows my position incorrectly but still within the radius stated. Not always, but often does. And somtimes even when I'm still sitting in my room, the "mylocation" icon moves constantly a few hundred meter.
So in my opinion, as a map, yes it is good. But as GPS, I doubt I could rely on it. But this happens on the built in map. Haven't tried another app tho.
After trying several GPS driving programs, I have settled on TomTom. I just completed a two day drive to ski in Colorado that covered 900 miles. My iPad was mounted in the center dash compartment with a minor modification. I used the GPS function for route info since I tried a new way of traveling. Since driving in Colorado is lousy for radio reception, I found a cable that would connect to the radio's input jack and had a USB plug for charging and played music from the iPad tunes. One of my GPS programs provided elevation readings through the mountains. Finally, I used Gas Buddy to plan the best places to get fuel.
My only problem was that the GPS programs are battery drains. No matter which charger I used, it would still drain. With the 2amp chargers, I went all day without going below 40%, but if we had done one of our 15 hour non-stop runs, we would have turned the GPS for periods to recharge. We also used the TomTom to find places to eat and Wal-Marts for rest breaks on the route.
I use the Magellan app with my iPad. I ran picture wire through and around my center dashboard air vents so that I could just open the iPad case and hang it over the wire - super simple and cost is almost nothing! My wife likes voice instructions and it was basically the same program as I had on an old Magellan GPS - but with several improvements and, of course, that nice big screen. I will occasionally switch to the map that came with the iPad to get a wider picture because the GPS app tends to show me a closeup view - but it works quite well. I drive all over Minnesota and, when I get out of range of good radio I switch to streaming radio. I also plug the sound into my car stereo and charge from a cigarette lighter charger - Rocketfish - and my iPad charges upward to 100% and stays there - nice to have a full charge in the evening after a day of driving.
Originally Posted by
Seadog
Hi. I'm reviewing feedback on navigation applications for the iPad. I like Tom Tom, as I have a handheld for my kids. I want to acquire a Voice enabled overlay for the iPad. Did you use TomTom on an iPad2? One feedback stated that TomTom support had said it is not supported on iPad2. Also, what are the subscription costs for the live traffic, and for map updates? One final question... Does this become a drain on the data plan to use? I'm used to Google maps, but need voice commands so I don't have to look at screen while driving. Your info is much appreciated. Thanks in advance.
Supporting Vendor
Seadog
actually i have never think about GPS, after reading your answer, i tried and it really great. thanks for sharing your idea.
Accessories for Apple, Repair Parts for Apple, Online Store | eKindom.com
Enjoy your iPad,
enjoy your life
Newer design, Cheaper price, Faster delivery
I am using the original iPad and have no problems. I cannot see what would be an issue with the iPad 2. I do not use voice commands or voice directions. I do not like being told how to drive. If I can't put up with my wife backseat driving, I am not going to listen to a machine. Most of the navigation demand is just like your dedicated GPS units. It is only when you do web searches or traffic updates that your data plan will get involved. For my tastes, the TomTom app works best.
Seadog
Thank you, Seadog. My interest is for the voice directions, so that I don't need to look at my unit unless I am approaching a challenging intersection. I really appreciate your recommendation. If you are aware of the subscription cost for map upgrades and for the Live Traffic, I would be interested in knowing. Thanks again
Doesn't really answer your question, but I'll throw my experience into the mix. I use the Garmin Nüvi. I have an SD card plugin with the Canadian oilfield locations built into it. One of the first things I did was to turn off the voice instructions. That was about two years ago and I've never felt the need to turn the feature back on.
I've never used the iPad as a GPS although I experimented with the iPhone when I first bought it. I found that the Garmin was much more useful, since my kind of driving is somewhat unusual, being mostly off road.
Better the pride that resides in a citizen of the world,
Than the pride that divides, when a colourful rag is unfurled.
And where does the power come from, to see the race to its end? From within.
Please read the
forum rules
Manuals for your equipment can be downloaded
here
I do not know exactly, because the prices vary according to which area app is purchased. The lifeime updates and traffic plans can cost up to $200 for the standalone devices.
- You may not post replies
- You may not edit your posts
Forum Rules
By Destroyer in forum User News Submissions
Last Post: 08-12-2011, 06:44 PM
By mobi1 in forum iPad General Discussions
Last Post: 04-08-2011, 02:24 AM
By williamkr in forum iPad Help
Last Post: 03-21-2011, 11:58 AM
By LambChop in forum iPad General Discussions
Last Post: 09-27-2010, 11:40 AM
By danriffle in forum iPad General Discussions
Last Post: 08-10-2010, 05:35 PM
'ipad gps 2012
best ipad 3 gps app
best ipad gps app 2012
best ipad3 gps apps
best navigation app for ipad 3
gps ipad
instructions to use tomtom on my ipad
ipad 3 gps navigation
ipad as car gps
ipad as gps device
ipad as gps in car
ipad car gps
ipad case that hangs off the dash
ipad in scion xb
seadog gps
tom tom on ipad 2 3g review
use ipad as gps
using ipad as gps
using ipad for gps in car
voice directions gps ipad
