Skype problem
This is a discussion on Skype problem within the iPad General Discussions forums, part of the Apple iPad Discussions category; downloaded Skype, logged in to my account, was able to make a call, but no sound, and I don't know whether any sound was being ...
Results 1 to 9 of 9
Thread: Skype problem
    126119
    2 times
    Nov 2011
    88
    Skype problem
    downloaded Skype, logged in to my account, was able to make a call, but no sound, and I don't know whether any sound was being sent out either. I have tried the Skype test call, and it connects, but I can't hear anything. My sound settings are on, and the sound is not muted. Do I need a headset with microphone to use this? Is there a microphone in the iPad? Obviously there are speakers, and they are working, as all other sound is on.
    Does anyone have any ideas please?
  2. #2
    70532
    6 times
    Jun 2011
    Springfield OH
    133
    I have made skype calls with iPad2, confirming microphone and speakers. I don't know about iPad1. I don't know why yours would not work.
  3. #3
    48665
    160 times
    Brisbane, Australia
    9,528
    I use Skype and no you don't need headphones. Have you looked at the control which is found when you bring up your multi task bar. Do the 4 finger swipe up or double press the home button and you will see your multi task bar along the bottom, swipe right as far as you can go and you will see a volume control slide here. Also another place in Settings - General - Sounds. If they are both fine and you say mute is not activated, try closing the App completely and relaunching it. Bring up your multi task bar again and press on the app until it jiggles and press the red minus sign that appears and this will close it. Now relaunch it and see if that makes a difference, let us know.
    iPad 2 64gb 3G
  4. #4
    150179
    Jan 2012
    NJ, USA
    I haven't been able to get Skype to work to make calls from my iPad 1, but on my iPad 2 it works fine. Not sure if this is a common problem or if there is a way to make it work on the iPad 1 or not.
    Duane
  5. #5
    126119
    2 times
    Nov 2011
    88
    Quote Originally Posted by leelai
    thanks leelai - the multitask settings were wrong- volume was on minimum. I have slid it to full and bingo!
    Happy bunny!
  6. #6
    126119
    2 times
    Nov 2011
    88
    Thanks Leelai. The multi task bar setting was the problem. I moved the slid from the left to the right and bingo!
    Happy bunny here.
  7. #7
    126119
    2 times
    Nov 2011
    88
    Thanks Leelia. The multitask slider was the problem. I moved it from left to right And bingo!
  8. #8
    48665
    160 times
    Brisbane, Australia
    9,528
    Quote Originally Posted by duaneswoon
    Duane
    I had heard that it was possible to use Skype on an ipad1 obviously with audio only. Try closing the app completely and then relaunch it. From the home screen do the four finger swipe up or double press the home button to reveal your multi task bar. These are all the apps that you have opened at one time. Long press the app until it jiggles and a red minus sign will appear above it. Press the minus sign, this will close the app, not delete it. It's a good idea to close all these apps regularly as it helps the iPad to run smoothly. Try Skype again and tell us if this has fixed it or not.
    iPad 2 64gb 3G
  9. #9
    iPad Guru
    49745
    137 times
    3,369
    Quote Originally Posted by duaneswoon View Post
    Duane
    Skype works fine on iPad 1, minus video. I loaded the Skype app and started using it. That's it. There were no special steps. I switched to Skype on iPad 2 once I got one of those, but it was the same process.
    I just tested to make sure things still worked, because I didn't want to steer you wrong if things had changed: I have two Skype accounts and I tried calling from iPad 1 to iPad 2, and vice versa, and both calls went through (without video, of course).
Sponsors
  1. Skype copy text problem
    By Aluston in forum iPad Help
    Last Post: 09-30-2011, 06:15 AM
  2. iPad 2 Skype volume problem - please help
    By janice1975 in forum iPad FAQ
    Last Post: 09-20-2011, 01:23 AM
  3. Skype problem on Ipad2
    By miguels in forum iPad Help
    Last Post: 06-07-2011, 10:50 AM
  4. iPad 2 skype problem
    By OzzyB in forum iPad 2 Forum
    Last Post: 04-26-2011, 06:26 AM
can't close skype test page on my ipad2
cant hear skype call on ipad
common problems with ipad2
do you need microphone for skype on ipad
does the ipad 2 have a speaker to use skype
how to multitask skype ipad
ipad skype mic volume
ipad skype volume control
microphone volume on ipad skype
my skype for ipad cannot make a call
no sound mic skype ipad
problem downloading skype for ipad
problem of skype in ipad
skype audio ipad
skype audio problems on ipad
skype for ipad gets audio only
skype sound problems ipad
two skype accounts one ipad
what do i need to download skype on my ipad 2
why is there no sound on my skype
