iPad 2 internal (headphone)sound is quite low!
This is a discussion on iPad 2 internal (headphone)sound is quite low! within the iPad General Discussions forums, part of the Apple iPad Discussions category; Ok so I got the 64 gig wifi white one..I am a music buff so I put in my SONY XBR 700 headphones ( bass ...
Results 1 to 10 of 14
    56495
    May 2011
    India
    389
    Ok so I got the 64 gig wifi white one..I am a music buff so I put in my SONY XBR 700 headphones ( bass heavy and loud..24ohm)....And straight away I felt the difference in loudness and bass...it's quite (very) low in comparison to my iPod nano (140$ only)..the punch of the bass is missing as well..I had to check several times with the sound level on the ipad as I cud not believe it!
    I do have a small amp to boost it but didnt want to carry it all around! Btw my f/w is 4.3.5..if it's got anything to do with that.
    Sent from my White iPad 2.
    15433
    23 times
    Sep 2010
    782
    Are you new to the iPad? There are seperate volume levels for with and without speakers. Not to sound ignorant but have you tried turning up the volume once the headphones are plugged in and the music is playing?
    56495
    May 2011
    India
    389
    yes i know hoe to use an ipad And yes its quite low as compared to ipod nano pr iphone 3G both which i own even my frnds ipad 1...so ipad in general is quite low on loudness and bass!
    52417
    18 times
    May 2011
    Dorset, United Kingdom
    287
    Have you ensured that you haven't got the 'volume limit' activated? If that's not the case I'm wondering whether it might be an actual problem with your iPad as I can listen to music through my headphones on just 1 or 2 bars most of the time.
    56495
    May 2011
    India
    389
    no problems dude..its a 2 day old ipad 2 and i checked my friends too...i guess u need to listen to the ipod nano first and then the ipad...then u will know the difference.
    15433
    23 times
    Sep 2010
    782
    Does it sound normal through the inboard speaker? If so, there may be an issue with the headphone port and it is not getting a full connection. Try pulling the headphone connection out slightly on the nano to compare. Does it sound similar?
    56495
    May 2011
    India
    389
    no man i heard i my friends ipad too..its the same..everywhere...it is a fact that ipad is less loud and bassier than the ipod or iphone
    15433
    23 times
    Sep 2010
    782
    Ahh, okay, you are making a general observation about the iPad. I thought you were seeing an isolated issue on your device.
    56495
    May 2011
    India
    389
    yea lol...it was a general observation and not a defect! :P
    56495
    May 2011
    India
    389
    OK GUYS..I have finally solved the problem..This sound low problem is only with the EUROPEAN and ASIAN shipped ipads as they are set to low levels due to country regulations..Here in INDIA its the same as EUROPE...The US ipads are loud as there is no sound restriction by GOVT. So this only works for ipads sold outside US. and it really works! My iPad 2 [India] is double in sound now through the heaphones
    Note: No changes in speaker volume..Only Headphones or internal.
    The solution to this problem is :-
    Step 1)- The first thing you have to do is Jailbreak your iPhone, iPod Touch or iPad. If you have not done this already there are many how to guides you can find around
    Step 2) - Next you are going to need to install the following Cydia tweak to your iPhone, iPod Touch or iPad:
    iFile
    Step 3) - open iFile. When you open iFile you should see a screen like this:
    Step 4) - With iFile open click on var in the top left corner, then click /
    You are now in the root folder.
    Click System then Library then PrivateFrameworks and then Celestial.framework.
    Browse for the RegionalVolumeLimits.plist file and click on it. Upon click on the blue arrow and set the permission to 777
    Now clicking the file you should be presented with the options depicted below.
    Step 5) - Click on Property List Viewer. Upon doing so you now have all of the volume settings for your iPhone, iPod Touch or iPad in front of you.
    Change all the values in this file as shown above from 0,83 to 25. Which means setting the volume limit from 83% to 125%.
    UPDATE: For ios 5+ its -
    System/Library/PrivateFramewor
    *ks/MediaToolbox.framework/Regi
    *onalVolumeLimits.plist
    For those of you that are running ios 6.0 or 6.01 :- its now under /system/library/frameworks/med*iatoolbox.framework
  1. External GPS device vs. IPad Internal GPS
    By gardavin in forum iPad OS
    Last Post: 03-28-2012, 08:45 AM
  2. Sound through one headphone only! help!
    By Sea Sik in forum iPad Help
    Last Post: 11-13-2011, 11:17 AM
  3. iPad 1 gen internal mic pressure contact???
    By Luchura in forum iPad DIY
    Last Post: 10-02-2011, 04:27 PM
  4. Small sound coming out of headphone
    By nguyen.linh2008@gmail.com in forum iPad Help
    Last Post: 06-15-2011, 11:02 PM
  5. Replies: 10
    Last Post: 06-05-2011, 03:58 PM
increase headphone volume on ipad
ipad 2 headphone volume too low
ipad 2 volume low
ipad headphone sound low
ipad headphone volume too low
ipad headphones low volume
ipad headphones volume too low
plt bbtgo quiet
