Good Day All,
I have been having challenges since when i got my iPad-2. The battery discharges almost 2hrs after is fully charged.
Can anyone tell me the way out.
This is a discussion on Battery Drain On iPad-2 within the iPad General Discussions forums, part of the Apple iPad Discussions category; Good Day All, I have been having challenges since when i got my iPad-2. The battery discharges almost 2hrs after is fully charged. Can anyone ...
Good Day All,
What version of iOS are you on? You'll see there were some problems with certain iPads when they used iOS5. There's a new release 5.0.1 that fixes battery problems.
I am running 5.0.1 and my ipad2 is draining faster than my iPhone 4s. This is unacceptable. Has anyone found anything in the OS preferences that will prolong battery life. I am about to play my "Apple Care" card and ask for a new battery. I feel it is draining faster now than it did when I purchased it months ago. In 2 days my iPad went from 100% down to 60% and I NEVER even touched it. This is a problem that needs attention soon.![]()
I've been an Apple user since summer of 1984. This is not like Apple. I pray for a solution soon ...
well..if i leave my ipad idle for two days on standby it drains around 10 %...so ur does look bad...my suggestion is get it replaced..the battery
Sent from my White iPad 2 in India
Hi and welcome to the Forum!
You battery certainly is discharging quickly, there are a few things you can do to minimise this though. Have a look at your mail settings and how you have them set up also some apps that have push notifications. These will still use battery if they are set to notify you and at what time intervals. Close Safari completely when not in use. Play around with your screen lighting and set it to a brightness that is acceptable to you. Do you have many location services running also, these will drain your battery faster also. Hope this helps.
iPad 2 64gb 3G
Leelai's suggestions above are good ones. However, it's difficult to imagine what one could have running that would completely drain a battery from a full charge in two hours as the OP implied. I'd strongly recommend seeing Apple about a battery replacement if that's the case.
On the other hand, if the iPad is "never touched" but notifications and polling for email, searching for wifi connections, etc. are going on constantly I can imagine using 40% of the charge in a couple of days. In any event, I'd suggest some careful testing with notification and email polling turned off. It often turns out that anecdotal impressions aren't reliable data points in cases like this.
You need to close all the "working" apps!
Double click your home button to reveal all the working apps.
Hold your finger on one of them until the red minus sign appears and the start closing them down. Do this every two or three days to save battery.
I can give u an example. My ipad 2 with Wifi on and screen brightness at 50 (half) and browsing drains 1% battery in around 5-6 mins. So try working this way and see if u get the same results.
Sent from my iPad 2 white 64 gb (ios 5.0.1) using iPF
