iMessage doesn't work? A possible explanation
This is a discussion on iMessage doesn't work? A possible explanation within the iPad General Discussions forums, part of the Apple iPad Discussions category; This forum often gets posts about iMessage not working well I have discovered on issue with it that is a possible cause for the send ...
Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By K1W1
Thread: iMessage doesn't work? A possible explanation
    61094
    6 times
    Jun 2011
    271
    This forum often gets posts about iMessage not working well I have discovered on issue with it that is a possible cause for the send button to be greyed out when it should otherwise work.
    When you start an iMessage there is a line called Subject on the input screen. If you simply type your complete message in the subject line the send button will always be greyed out.
    When sending an iMessage you must either;
    Type a subject and then type text into the text space below the subject line.
    or
    Leave the subject line blank and just type your message in the body space.
    The next time that your iMessage won't send check where you have typed it it's very esay to start typing in the subject line by mistake.
    Personally I would call this a bug I can't see why a system like iMessage needs a subject header but maybe others see differently, obviously Apple do.
    Tim SPRACKLEN likes this.
    116 times
    15,249
    Thanks for that great explanation. Much appreciated.
    46070
    53 times
    Egremont
    979
    You could always turn the subject field off in settings - messages. Don't really see the need for a subject field for the type of messages that will likely be sent via imessage.
    61094
    6 times
    Jun 2011
    271
    Quote Originally Posted by DefBref View Post
    That's a great tip. Thanks I didn't know that you could do that.
  1. How does imessage work, Who do I send it to?
    By No1zeppelinfan in forum iPad Apps
    Last Post: 10-24-2011, 05:13 AM
  2. Why doesn't maps work?
    By dkilcullen in forum iPad Help
    Last Post: 09-17-2011, 04:53 PM
  3. The app doesn't work right...
    By M325i in forum iPad Apps
    Last Post: 06-14-2011, 09:08 AM
  4. Why Jobs Flash explanation doesn't make sense
    By romanr in forum iPad General Discussions
    Last Post: 04-26-2011, 09:37 PM
  5. Why doesn't my map work?
    By W4KRR in forum iPad Help
    Last Post: 12-26-2010, 09:15 AM
i message doesnt work
imessage doesn t work
imessage doesn't send
imessage doesn't work
imessage doesnt send
imessage doesnt work
reasons why imessage doesn't work
what to do when imessage doesn't work
why doesn't imessage work
why doesn't imessage work sometimes
why imessage doesn t work
