how does the ipad handle keystroke events at the document level
This is a discussion on how does the ipad handle keystroke events at the document level within the iPad General Discussions forums, part of the Apple iPad Discussions category; I am working on a web application for my company that uses an iPad and a bluetooth barcode scanner as portable input devices. At first, ...
I am working on a web application for my company that uses an iPad and a bluetooth barcode scanner as portable input devices. At first, I used an input field to capture the scanners output and submit the form. The problem is, once the screen reloads, there is no way to get the input field to get focus. This results in the user having to tap the field before each scan or the input is ignored. I have tried several methods of focusing on the field when the page loads, but it seems that the javascript 'focus()' method simply will not work without user input such as tapping a button.
So that was a dead end...then I tried to tie an event listener to the document object with document.addEventListener('keydown', doit, false) (which works just fine on the full version of safari). Again, the ipad ignores the input until I tap on a form field. Any Ideas?
06-10-2010 06:01 PM
I am having the exact same issue, and I was just about to begin playing with code to fix it.
Which methods did you try without any luck?
I was planning on a very simple:
<body onload="document.formName.elements[X].focus();">
(where X is the field # I want to begin with)
Did you try something along these lines and it failed to work? I would have though this would be just fine.
Could something like this work?
HTML:
Code:
<body onload="tigerFunc()">
<input type="text" id="monkeyForm" />
JavaScript (external file):
Code:
function tigerFunc()
document.getElementById('monkeyForm').focus();
Or have you already tried that?
When the birds start singing you should shut down your computer and go to bed.
Sweden
Jailbroken 32GB iPad Wi-Fi + 3G
Yes, I have tried that as well. It seems that triggering a focus event on a form field with page load by direct means or by execution of a function does not work. However, if you tie the same function to a touch event or button press, focus works. I have a gut feeling that apple has deliberately done this to prevent the keyboard from appearing on page load.
I have even gone as far as trying to capture keystrokes instead of using a text field. These methods will not work until you press something on the screen to give some element focus. I tried tying event listeners to the document and window objects, alas, no luck.
I have tested all of these methods in safari on my Mac Mini and all have worked until i load the same page on the iPad.
As I type this, I have another idea to try. The problem, in its simplest form, is the fact that no object has focus on page load. What if we don't submit the data with a traditional form submit? It might be possible to intercept the carrage return at the end of the string and use an AJAX call send the data and supply a callback function that inserts the return data into a div. This I have done before, but the trick here is clearing the content of the text field and maintain focus for the next scan. I will give it a shot an post my results back.
Originally Posted by
mrgad
got it
here is the solution I came up with....
Code:
<?php
if(isset($_REQUEST['data']))
$output=$_REQUEST['data'];
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<title>test page</title>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
<script type="text/javascript" src="../includes/js/jquery-1.4.2.min"></script>
<script type="text/javascript">
function testit(e)
var fdata=document.getElementById('data').value;
$.post("ipadtest.php", $("#testform").serialize(), function(data){
$('#output').load("ipadtest.php?data="+fdata+" #output");
document.getElementById('data').value='';
return false;
</script>
</head>
<body>
<form name="testform" id="testform" onsubmit="return testit();">
<input type="text" id="data" name="data" />
</form>
<div id="output"><?echo $output;?></div>
</body>
</html>
This is a simple test using jquery libraries to accomplish a ajax request. because the text field never looses focus, you can scan several times without having to touch the screen. It just requires that you touch the text field when you are ready to begin scanning.
- You may not post replies
- You may not edit your posts
Forum Rules
By Checkpoint in forum iPad General Discussions
Last Post: 08-02-2010, 06:11 PM
By omro in forum iPad Apps
Last Post: 06-05-2010, 04:10 PM
By B0269h in forum iPad Help
Last Post: 06-01-2010, 06:10 PM
By Lederman in forum iPad Help
Last Post: 05-19-2010, 10:19 AM
Last Post: 04-27-2010, 03:12 PM
+ipad submit form with javascript
any keystroke submits the form ipad
does ipad 3g record keystroke
focus event in ipad javascript
html form input ipad go button not button
ipad barcode .focus
ipad dock keyboard scan codes
ipad focus input
ipad how to handle keyboard enter javascript
ipad input focus
ipad javascript focus input
ipad javascript next key
ipad keyboard events
ipad mimick keystrokes via javascript
ipad remove focus from input javascript
javascript and ipad keyboard listener
javascript set focus ()ipad
jquery ipad key event
key event ipad javascript
safari ipad key event
Tags for this Thread
