Ios 5 battery draining
This is a discussion on Ios 5 battery draining within the iPad General Discussions forums, part of the Apple iPad Discussions category; Hi don't know if anyone else is experiencing this but I updated to IOS 5 on my IPAD2 early yesterday and have since done so ...
Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By GoPackGo
Thread: Ios 5 battery draining
    66577
    Jun 2011
    Hi don't know if anyone else is experiencing this but I updated to IOS 5 on my IPAD2 early yesterday and have since done so noticed my battery is draining so much quicker ??? Please tell me it's not just my IPAD !!!!! 😳 I love the new upgrade up don't understand why my battery is going so quick ?? Can anybody advise ? Thank you
    iPF Super Guru
    40746
    93 times
    NW Left Coast
    3,504
    I've been using mine pretty steadily since upgrading around noon on the 12th and haven't really noticed any difference. You might want to try closing all of your open apps. Some/most go into a "wait state" when you're not using them, but some continue to draw power and resources to function. Double click the home button, tap and hold any app icon until they all start to jiggle, then tap on the circled "minus" in the upper left-hand corner of each app.
    If that doesn't help, try resetting your iPad. Hold down the power switch and home button until the slider appears on the screen and shut it down. Hold down the power switch again until the Apple logo appears. Fully booting up from a reset will take a little longer than a restart.
    More here:
    iPhone, iPad, iPod touch: Turning off and on (restarting) and resetting
    Let us know if that helps. Others may have some more suggestions as well.
    Welcome again and enjoy!
    90362
    28 times
    Aug 2011
    Milwaukee, WI
    960
    My battery, I've found, drains really fast every once in awhile for a seemingly unknown reason. But today, for example, I had just as much juice as I usually get, 95% of the time. So iOS 5 didn't effect that for me.
    Lindsey
    Black 16GB iPad 2 | Jailbroken via Absinthe
    White 16GB iPhone 4S | Jailbroken via Absinthe
    iPF Super Guru
    40746
    93 times
    NW Left Coast
    3,504
    A couple of things that can really affect battery life is heavy WiFi or 3G use, particularly if map/GPS apps are being used. Of course watching movies uses a lot of power. However the biggest drain on the battery is often the iPad's screen itself. The brighter the screen the faster the battery will drain. Often setting the iPad's screen brightness to 75% or even 50% will extend the battery life an hour and often more.
    90362
    28 times
    Aug 2011
    Milwaukee, WI
    960
    See, when I raised my brightness to about 35% (I usually have it on 15%) my battery started draining like crazy. So unless I need it brighter, I settle for the dim screen. And yeah, certain apps drain my battery. I was surprised though - I was on Skype for nearly 2 hours last night with my brother and the battery drained like 10%. *** @ that, that's incredible!
    Tim SPRACKLEN likes this.
    Lindsey
  1. Draining battery to 1%?
    By graywolf in forum iPad General Discussions
    Last Post: 02-23-2012, 11:25 AM
  2. Battery draining fast...
    By MoonlitSonata in forum iPad 2 Forum
    Last Post: 06-09-2011, 01:13 AM
  3. Tips on draining ipad battery?
    By Mv-ixius in forum iPad General Discussions
    Last Post: 01-02-2011, 10:33 PM
  4. Battery Draining
    By dhender in forum iPad Help
    Last Post: 12-25-2010, 01:37 AM
  5. What have I downloaded that is draining the battery?
    By barriejohn69 in forum iPad Hacking
    Last Post: 07-20-2010, 05:47 PM
batter draiinig ios5
ios 5 battery drain ipad 2
ipad 2 ios 5 battery drain
ipad battery draining fast
ipad battery draining too fast
ipad battery draining too fast with ios6
ipad battery drains quickly ios 5
ipad draining battery fast
my ipad's battery drains even when is off
why is my ipad 2 battery draining so fast
why is my ipad battery draining so fast
why is my ipad2 battery draining so fast
